check engine light
Old May 21, 2008 | 10:05 AM
vtecthis1's Avatar
vtecthis1
Default check engine light
hi,
my check engine light came on after i decided to clean my butterfly on the throttle body, and the MAF, and the connections for the MAF and TPS... It does not accelerate past 3k rpm, and will nose dive when i try. also, when idling, the idle is lower than normal and there is the smell of catalytic converter.
I used the sea foam (deep creep) for the throttle body, and electrical connection/terminal cleaner for the connections, and lastly, i used MAF cleaner for the MAF!!
anyone have any suggestions as to what it may be. I already disconnected the battery, but it comes right back on... I cannot seem to find the plug that i can bridge to cause the ecu to flash a code, can anyone tell me where it is? thanks-mike
Old May 21, 2008 | 11:12 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Old May 21, 2008 | 11:23 AM
Dx3's Avatar
Dx3
Mike,
It is on the drivers side of the timing belt cover by the upper intake manifold runners (if you are in a 300), not sure about a 400.
Here is a picture from a turbo Lexus but it is in the same place
Jonny
Old May 21, 2008 | 11:39 AM
vtecthis1's Avatar
vtecthis1
that is just the diagnostic port, i was told that there is a jumper wire to cause the ecu to flash a code... also i just read that i should pull the fuse for the for the EFI to clear it... i have the 400...
thanks
Old May 21, 2008 | 12:02 PM
Dx3's Avatar
Dx3
thanks
What exactly do you think the diagnostic port does Trust me on this, I've been around a while...
You have to get a jumper wire that you put in the E1 and TE1 slots IN THE DIAGNOSTIC PORT to get the trouble codes.
Jonny
Old May 21, 2008 | 03:40 PM
vtecthis1's Avatar
vtecthis1
ok thanks for that it worked... at giving the code.. which was a 31: volume air flow meter signal.....now what?
Old May 21, 2008 | 05:01 PM
Dx3's Avatar
Dx3
MAF's are very temperamental - especially on these cars. I would venture to guess your MAF is mad at you and wants replaced.
Try pulling the -neg battery cable for a couple of hours. If that doesn't help, I would guess you damaged your MAF.
BUT, I am not a mechanic, nor do I pretend to be one. I have encountered a lot of MAF problems in my years though
Jonny
Old May 21, 2008 | 06:57 PM
98LexLs's Avatar
98LexLs
sounds like you should pull the mass air flow back out and make sure the two elements are not touching or that there is no oily residue. also check to make sure your throttle blade is not stuck
jonas's RX
Feb 24, 2018 04:02 PM
VW_Vanagon
Mar 22, 2009 07:20 AM
breakb
Maintenance
Oct 20, 2008 04:56 PM
LittleMous
25
Feb 25, 2008 12:40 PM
BlakSC
Sep 15, 2007 06:48 PM
