Solution to Creaking Front End Problem W/ Pics
Old Aug 1, 2011 | 10:33 PM
  #61
TechGreek's Avatar
TechGreek
The front end feels like butter now - minus the popping - but I found the popping noise with my handy dandy iphone.
http://www.flickr.com/photos/62248602@N05/6000693424/
Old Aug 17, 2011 | 02:29 PM
  #62
94SupraTT's Avatar
94SupraTT
Excellent thread. Actually found it from a link on supraforums. I plan on doing this (subframe bolts too).
Old Aug 19, 2011 | 05:02 AM
  #63
Nova's Avatar
Nova
this should def be a sticky, im going to be trying this tomorrow. currently i have the popping/creaking noise only while breaking at first i thought i left a caliper loose or something after a break job but double checked and everything is tight.
and techgreek way to use technology to your advantage! im lucky where i have people in the shop to help me diag noises
Old Aug 20, 2011 | 05:55 AM
  #64
94SupraTT's Avatar
94SupraTT
I'm going to try to do this today. Does anyone have any tips on torquing these down? Any help hints are appreciated.
Old Aug 21, 2011 | 02:42 PM
  #65
Nova's Avatar
Nova
use a torque wrench?
Old Aug 22, 2011 | 03:45 PM
  #66
Nova's Avatar
Nova
this worked perfectly!! my noise is gone!!!
Old Aug 29, 2011 | 07:05 AM
  #67
Harpo's Avatar
Harpo
The four 17mm bolts on the aluminum frame were loose on my SC300, I tightened them all nearly a full turn. Creaking noise is now gone, drives better too!
Thanks for a great thread, needs to be a sticky!
Old May 2, 2012 | 03:27 PM
  #68
hopmuzk's Avatar
hopmuzk
Well 2 independent mechanics and 1 Toyota mechanic with no idea what the problem was. I
(with very little mechanic background) found this thread and fixed the popping noise on my 1998
LS400. Thank you so much for all the information in this thread. It was absolutely invaluable for me. The Toyota mechanic said to POSSIBLY find the problem he would need 2 hours labor at $99.00 an hour. Thanks again.
Old May 3, 2012 | 04:09 PM
  #69
Oxford's Avatar
Oxford
After trying to find out what my cracking sound I gave this a try. It was night and day, all the noise is now gone and the car feels solid. I have 172k Miles on my sc300 and would recommend this to anyone!!!
Old May 27, 2012 | 04:37 PM
  #70
2JTsc300's Avatar
2JTsc300
I just replaced my LCA bushings at work a couple weeks ago and on my way home when i hit the brake i herd a big pop noise from the driver side. i thought i left a bolt loose after the alignment. tomorrow im going to try and tighten those 10 bolts up and see what happens. i hope it will fix it
Old May 29, 2012 | 10:27 AM
  #71
moosejaw2's Avatar
moosejaw2
I'm going to do this tonight as well
Old May 29, 2012 | 11:26 PM
  #72
baloyr's Avatar
baloyr
hmmminteresting
Old May 30, 2012 | 04:52 AM
  #73
TechGreek's Avatar
TechGreek
You guys need to make sure the FSM procedure was followed in the torque procedure on the LCA bolts.
Old May 30, 2012 | 09:58 AM
  #74
xspsi6's Avatar
xspsi6
Yes this is very often over looked and also a common issue with all the diy people changing out lca's. I will see if I can upload the procedure here.
Old Nov 11, 2012 | 01:43 PM
  #75
Zoolander's Avatar
Zoolander
Originally Posted by bcsc400
We tried this on my friends 92, they were all tight.
The strange thing with his car is that the noise dramatically decreases after the car has been on a long run and the engine bay is warmed up.
This is my issue as well. 01 GS430
