ls400 brake install
Sep 21, 2008 | 02:27 PM
Quote:
Originally Posted by
Curry
I did the brakes this weekend. They did fit BUT it was easier to do it when we shaved it a little... only took a few seconds.
What did you shave ?
Sep 21, 2008 | 04:46 PM
It was a small area on the bottom of the caliper.
Oct 16, 2008 | 02:27 AM
Does anyone know if is300 17 in rims fit over ls400 calipers/rotors?
Oct 17, 2008 | 09:05 AM
Ryeno
i dont think so, from what i know, but i can be wrong. the is300 wheel spoke design seems to be too inward to make a bbk fit.
Oct 14, 2009 | 10:02 AM
anybody has pic of what has to be shaved off the caliper?
Oct 14, 2009 | 10:23 AM
Dec 5, 2009 | 03:57 PM
did anyone end up using the stock sc brake lines into the ls400 brakes? i end up using mine but the screws... screws into the calipers but however the side piece next to the screw does not line up with calipers is it still safe to use the stock sc brake lines?
Dec 5, 2009 | 04:10 PM
I'd say yes. You should be ok.
Dec 5, 2009 | 04:13 PM
That little shave won't affect a thing
Dec 19, 2009 | 05:14 PM
I just did the install of the LS calipers and they look great and feel good when i brake hard but is it suppose to be musshy when i hit the brake under normal braking ???????
Dec 19, 2009 | 07:35 PM
Did you have new rotors/pads? I suggest you break them in first before braking hard... Did you bleed the lines properly?
Dec 19, 2009 | 11:18 PM
masagsxr
they have been broken in properly and I did bleed them so i dunno how did urs feel before and after the swap
Dec 20, 2009 | 12:49 AM
Must be the anti-lock brakes working then. I have SS lines but its not as hard as what I was hoping it to be. Overall, its definitely a good upgrade.
Greg5OH
Feb 20, 2014 11:29 AM
moviepilot
Maintenance
Jul 25, 2011 09:29 AM
Bradster
Apr 23, 2010 10:58 AM
Gs L-tune
Mar 15, 2006 12:30 AM
tvd51
Apr 24, 2003 09:22 AM
350 ,
9010512228 ,
bolt ,
bolts ,
caliper ,
claws ,
harding ,
horace ,
lexus ,
ls400 ,
number ,
part ,
pattern ,
piston ,
stickers
