Help! Head Bolt Size
Old Apr 29, 2008 | 02:01 PM
1siksc's Avatar
1siksc
Default Help! Head Bolt Size
Head Bolt Size... does anyone know the size of the Hex "allen" bit for this???!! Thanks ohh and i did search for awhile no results.
Old Apr 29, 2008 | 02:26 PM
Gunnar's Avatar
Gunnar
It's a 12-point, called a "bi-hex" or "triple square". Going off the advice I'd read on the forums I got a 10mm but it was too small, so I'm guessing it's a 12mm. (unless my 10mm was just packaged wrong and was really something smaller)
I used a 10mm allen head socket that I had from the bolts that connect the axles to the differential and it worked, but I would definitely suggest getting the right part to give yourself the most protection against stripping it.
Old Apr 29, 2008 | 02:35 PM
1siksc's Avatar
1siksc
ohh, im talking about the head bolts that bolt the head to the block.
Old Apr 29, 2008 | 03:00 PM
Gunnar's Avatar
Gunnar
So am I.
Old Apr 29, 2008 | 03:13 PM
1siksc's Avatar
1siksc
these.....
Old Apr 29, 2008 | 03:35 PM
5sp_jzz30's Avatar
5sp_jzz30
^^^^^those are not head bolts lol.
those are the plugs that go to cover the cylinder head. if you take it off it is only like half an inch thick and you will see into the head and oil will be there.
you have to take off the valve covers to see the head bolts.
what are you trying to do?
Old Apr 29, 2008 | 04:06 PM
1siksc's Avatar
1siksc
wow, im retarted! derr thanks!... ohh, im replaceing my head gasket.
m1k3yg
GS - 1st Gen (1993-1997)
May 3, 2012 02:57 PM
copermn
Jul 26, 2011 11:29 PM
DRFT103
Apr 28, 2010 10:32 AM
GKourp
Oct 14, 2008 10:35 PM
tuninghaus
Dec 19, 2006 10:57 AM
