Rear Rotor & Pads Change
Old Apr 24, 2008 | 05:21 AM
mousiee's Avatar
mousiee
Default Rear Rotor & Pads Change
This weekend I plan on changing my rear rotors and pads, and wanted to ask the forum if there is anything I should look out for? I also will be changing the calipers due to the passenger side sticking and causing premature pad wear. I am replacing the rear rotors with ATE, and pads with akebano ceramics. The calipers will be just oem replacements I got from Aliga.
Anything you all can think of that might slow me down or cause any hiccups would be of appreciation
Thanks
Mousiee
Old Apr 27, 2008 | 02:15 PM
mousiee's Avatar
mousiee
This is what I used to paint the calipers and hub.
Note: I didn't use the clear on the hub.
Old Apr 27, 2008 | 02:17 PM
mousiee's Avatar
mousiee
Calipers painted
Old Apr 27, 2008 | 02:18 PM
mousiee's Avatar
mousiee
Caliper brackets
Old Apr 27, 2008 | 02:20 PM
mousiee's Avatar
mousiee
Driver side all buttoned up!
Old Apr 27, 2008 | 02:22 PM
mousiee's Avatar
mousiee
Passenger side all buttoned up!
Old Apr 27, 2008 | 02:24 PM
mousiee's Avatar
mousiee
The ugly!!!!!!!!
Old Apr 27, 2008 | 03:22 PM
Damned04's Avatar
Damned04
Looks really nice, how do the ceramic pads bite?
Old Apr 27, 2008 | 03:33 PM
mousiee's Avatar
mousiee
Not really sure since I haven't drove it since the install. I will let you know tomorrow.
Thanks
Mousiee
Old May 1, 2008 | 01:13 PM
osugrad05's Avatar
osugrad05
did you have trouble pulling the rotor off the back?
Old May 6, 2008 | 05:12 PM
mousiee's Avatar
mousiee
No trouble at all thanks to a thread I found here. I just used one of the four screws that holds the radiator. I screwed it into the holes where the rotor sits on the hub and they popped right off.
Mousiee
Old May 6, 2008 | 05:40 PM
jspecdan's Avatar
jspecdan
lookin good yo. those are some tiny rear pads. i'm surprised it's a 1-pot caliper as opposed to a 2-pot opposed caliper like the 2GS.
Old May 6, 2008 | 07:47 PM
mousiee's Avatar
mousiee
Thanks!
You would think they would've had 4-pot upfront and 2-pot in the rear as heavy as the car is.
Old Jun 30, 2008 | 07:34 PM
DiRocco's Avatar
DiRocco
Default Ceramic vs Semi-metallic
Very well done Moussiee, looks great!
Are the ceramic pads quieter and more effective in your estimation? I had not noted a response to Damned04's question. Looking to upgrade to ceramic here as well.
Old Jul 1, 2008 | 07:55 PM
mousiee's Avatar
mousiee
Thanks DiRocco!
My car has never had anything but ceramic pads since I've owned it. The pads bite pretty good, but there is very little dust.
When my fronts wear out I plan on going LS 4 Pot calipers and braided lines. I have to order spacers due to the fact that I'm running SC430 wheels.
Mousiee
Skier76
Aug 3, 2018 12:00 PM
jackkpts
Jan 6, 2016 10:30 AM
Cozmo
Jan 9, 2014 09:28 AM
Billbosh
Wheels, Tires & Brakes Forum
Jun 17, 2004 06:23 PM
Billbosh
Suspension and Brakes
Jun 16, 2004 12:09 PM
