Memory seat question
Old Apr 7, 2008 | 09:06 AM
Ted_Se7en's Avatar
Ted_Se7en
Default Memory seat question
Hello all of you, I'm new here, just bought a '92 SC400 full stock (good looking too for its age), just have a question about the memory seats. The electric seats are working perfectly, but impossible to memorize the positions. I followed the manual instructions, doesn't work.
Any idea what it could be?
Thx in advance for your answers (I got more )
Old Apr 7, 2008 | 09:52 AM
evileagle's Avatar
evileagle
check to make sure the key to the ignition is in the correct spot. If i remember correctly, its in ACC.
second, make sure the parking brake is up. It its not, it wont move(safetly precation)
hope this helps
GL
tcrow31's Avatar
tcrow31
Does ur key less entry and alarm work? If not then flip the switch on the bottom of the steering column and turn it on. The memory seats are tied into the alarm system. If that doesnt work check the plug in the back of the buttons and make sure its connected. For any other question search the Audio and Security section for more assistance.
Old Apr 7, 2008 | 09:56 AM
Ted_Se7en's Avatar
Ted_Se7en
Thx for the quick answers
I'll have a look at these tips!
Old Apr 7, 2008 | 12:42 PM
LexAnt's Avatar
LexAnt
parking brake up doesn't matter. the car has to be in park.
Old Apr 7, 2008 | 01:42 PM
Mr.NA_T's Avatar
Mr.NA_T
welcome.....
Any pix?...........
Well, try and disconnect the battery?
Old Apr 7, 2008 | 02:00 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
your foot cannot be on the brake, and resseting via the battery is a good idea cause sometimes when it gets stuck the ecu will not respond until a reset.
also make sure your steering wheel tilt works fine and your sidview mirrors work as well. any of these not working right will cause the memory ecu to freeze when it tries to move them.
evileagle's Avatar
evileagle
For us 5spd guys, yes it does matter....
Old Apr 7, 2008 | 02:18 PM
5sp_jzz30's Avatar
5sp_jzz30
....until you replace your stock seat for a manual racing bucket
Old Apr 7, 2008 | 04:11 PM
Ted_Se7en's Avatar
Ted_Se7en
Originally Posted by Bkjasonp
welcome.....
Any pix?...........
Thank u
Well pix, I got some, but take any '92 SC400 full stock in pearl white and you've got my car
I'll try to disconnect the battery since everything else didn't worked.
Will do that as soon as I have my cluster back (should be tomorrow)... white leds, red needles
Old Apr 7, 2008 | 04:12 PM
Ted_Se7en's Avatar
Ted_Se7en
Everything work perfectly (steering wheel tilts, seats are moving in every directions, rearview mirrors are working...)
Last thing I need to check is the buttons on the door. Dunno if it's hard to remove though
Old Apr 7, 2008 | 05:52 PM
Ted_Se7en's Avatar
Ted_Se7en
ahem, anybody have any idea on how to remove the memory seat control panel? Don't want to break anything. Thx
Old Apr 7, 2008 | 06:26 PM
LexAnt's Avatar
LexAnt
well he doesn't have a 5spd, hence why i said that it had to be in park.
another possible reason is the ecu under the seat may not work as well.
Old Apr 7, 2008 | 06:35 PM
FormosaSC's Avatar
FormosaSC
to remove, you need to remove the whole panel, i think you have 3 small bolts at the bottom of the panel, 2 thats close to the door hinges, 1 behind the door open lever (from the inside), 2 under the door armrest.
Once the panel comes off, you need to disconnect the door lock and the door opener, they come off, you just need to position them to do so. Then unhook the window switch. NOW check to see if the connector is properly plugged in for your memory seat control, or you can remove it and check it that way.
Old Apr 7, 2008 | 07:43 PM
Ted_Se7en's Avatar
Ted_Se7en
Thx a lot for the info, not exactly the piece of cake I thought this would be, I'll wait a while before doing that
LexAnt: ECU under the seat???
