Lower Control Arm DIY
Old Mar 17, 2008 | 06:59 PM
  #31
97-SC300's Avatar
97-SC300
the front uppers are easy. one nut and the really long bolt. plus a ball joint.
Old Mar 17, 2008 | 07:29 PM
  #32
over40driv's Avatar
over40driv
Sorry, missed the last two pages.
Old Jul 10, 2008 | 10:56 AM
  #33
RolxuSC400's Avatar
RolxuSC400
Default Sorry to Resurrect Old Thread
New control arms came in gonna attempt this weekend. Nice write up but I had a question...I noticed there is no mention of torqueing the bolts when done. Is that not required? I would think that a suspension component would require it. I couldnt find any torque specs whatsoever in the post unless I missed it.
Old Jul 11, 2008 | 05:26 AM
  #34
RolxuSC400's Avatar
RolxuSC400
Found specs on my own. Went to dealer and they printed off the DIY for me with the specs.
Old Jul 22, 2008 | 05:48 PM
  #35
over40driv's Avatar
over40driv
RoluxSC400
Old Jul 22, 2008 | 05:51 PM
  #36
over40driv's Avatar
over40driv
RoluxSC400, how about sharing the tourque specs. with us, I agree important.
Old Jul 25, 2008 | 07:57 AM
  #37
horent135's Avatar
horent135
How you know if your control arm is bad or going bad?
Old Jul 25, 2008 | 08:06 AM
  #38
RolxuSC400's Avatar
RolxuSC400
Over40driv - Sorry I completely forgot to put them up here. I have been running into problems gettin mine off and had to replace bolt on 1 side and gettin ready to do other side tonight. I will do so when I get home.
Horent - look at the bushings...if they are cracked as mine were then its time. Mine only had 84k on them too. Probably not imperative I do them but if you look at the OP for this DIY his DEFINITELY needed to be replaced. Also going over bumps or potholes you'll hear a clunking noise.
I am swapping with the Supra lowers too and they are spot on and ALOT less $$$$$$.
Old Jul 29, 2008 | 01:11 AM
  #39
LEXPLAY's Avatar
LEXPLAY
after reading this yesterday i pulled both mine out in about a hour. getting the vlamous bushes put in today and should have her back on the road tonight. the bushes were worn out like i thought.
Old Jul 29, 2008 | 05:47 PM
  #40
EpixINC's Avatar
EpixINC
hey thanks for all the THUMBS UP comments. yeah torque specs? no idea, i just tightened them to what felt right, then got the alignment after all done. they probably retorqued them all. havent had any problems with it since
Old Jan 2, 2009 | 05:16 PM
  #41
TLW's Avatar
TLW
Great thread, I need to do tomorrow. to EpixINC
Old Jan 7, 2009 | 02:39 PM
  #42
lfrers's Avatar
lfrers
FRONT SUSPENSION
Lexus LCA forward bushing (1 per side): #48654-24040 I was quoted 1998 $61.27
Lexus LCA rear bushing (1 per side): #48655-24050 I was quoted 1998 $77.84
Both from:
Lexus Of Escondido (760) 233-5000
5444 Paseo Del Norte Carlsbad, CA
The parts guy checked to make sure they would be orderable and not just referred back to the whole control arm and apparently you can get a set of 4 OEM front LCA bushings for $278.00 from them.
I just read on another thread that the 98 bushings will work for 92+. So these should work for anyone wanting to do OEM LCA Bushings and still have the cushy ride without having to buy arms. Just make sure your ball joint is in OK shape.
Old Jan 27, 2010 | 03:16 PM
  #43
SRT102JZ's Avatar
SRT102JZ
I have a set of R2 Racing CA Bushing Kit for upper and lower for both front and rear. I originally bought these for my 95 NA supra but never put them on. what do i need to do to make these fit on my 96 sc300? im assuming ill have to put on supra CAs but will i need all 4 supra CAs (upper&lower, front&rear)? and will they fit on the sc without any problem?
Old Jan 29, 2010 | 04:28 PM
  #44
SRT102JZ's Avatar
SRT102JZ
anybody? id like to get these installed asap
Old Feb 8, 2010 | 07:01 PM
  #45
MongooseGA's Avatar
MongooseGA
Do you have to remove the brakes in order to get the control arms off, or will having the car on a lift alleviate that?
I had originally intended to do the job at home, as I have the press and the torch needed to replace the bushings in my arms, but it may be worth the few bucks to rent a lift at the hobby shop on base instead.
