Lower control arm ??
Old Feb 29, 2008 | 10:26 AM
ekrebs's Avatar
ekrebs
Default Lower control arm ??
Heloo again,
Just wanted to get some input on a concern of mine, will a bad LCA damage suspension in any way??
Thanks
Old Mar 4, 2008 | 11:45 AM
ekrebs's Avatar
ekrebs
No one out there that can help me out?
Old Mar 4, 2008 | 04:30 PM
TheMole's Avatar
TheMole
By bad lca do u mean the assembly, the bushing, the balljoint?
Old Mar 5, 2008 | 08:42 AM
ekrebs's Avatar
ekrebs
The Bushing is shot!
Old Mar 5, 2008 | 10:28 AM
TheMole's Avatar
TheMole
It might throw off your steering and make the ride unstable on rough roads. May also throw off your alignment, cause uneven tire wear, or make clunks from the front end. Should be ok for a while if you drive conservatively. The balljoints may be on their way out since the bushings are bad already so you gotta watch out for those.
Old Mar 5, 2008 | 11:08 AM
ekrebs's Avatar
ekrebs
My TT LCA's are on the way so i should be swaping them both out this weekend, I was just worrried i was going to damage the new suspension.. from your last reply it seems as though i should be okay, right?
Thanks for your input!!
Old Mar 5, 2008 | 11:17 AM
TheMole's Avatar
TheMole
Yea should be ok as long as you aren't road racing or drifting.
I think you will like how those supra lcas feel when you get them on. Don't forget to get an alignment right after.
Old Mar 5, 2008 | 11:23 AM
ekrebs's Avatar
ekrebs
I will, Thanks again
Old Mar 6, 2008 | 07:07 PM
ekrebs's Avatar
ekrebs
Okay im about to undergo the supra TT LCA's on my SC and i could use as much advise as possible!!!
A. Is this something i can do in my garage?
B. Any pain points?
Thanks
Old Mar 6, 2008 | 08:02 PM
Steelwheel's Avatar
Steelwheel
Don't have a link on how to change the SC's lca. I changed mine with FSM, but here is a link to an LS400 change that might give you an idea whether you would want to try it. It may not be just like the SC, but close in difficulty:
http://www.lexls.com/tutorials/suspe...flowerarm.html
Someone may want to post a link, or you may search to find one showing a DIY for SC400 or Supra.
Also, if you bring it to a good suspension shop, they should be able to do it pretty quickly with a lift.
Good Luck.
Tim
Old Mar 6, 2008 | 09:09 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
B. Any pain points?Thanks
Yes and yes.
Unless you need to be spoon fed by who ever feels like re-doing a well documented dyi, just type the words "Lower Control Arm" in the search button and specifiy SC300 400 Suspension and Brake" and you will find a freaking mountain of info by the many who have gone before you.
seanmwple
Oct 6, 2017 12:50 PM
rominl
Suspension and Brakes
313
Jan 18, 2017 08:25 PM
Slvr surfr
Dec 30, 2015 07:24 PM
Kharizma
14
Apr 27, 2006 10:08 PM
joshoowa
Oct 13, 2005 10:00 AM
