noobest question, EVER.
Old Feb 23, 2008 | 06:15 PM
rootaku's Avatar
rootaku
Default noobest question, EVER.
Ok well, I was just wondering. How do you remove stick "rims" "wheels" off a 92' SC300? Friend told me I just can just stick a flat hand screwdriver on the side and pop it off... I'm a little scared of stabbing the wheel so anyways, Is that how you do it? >_<
Old Feb 23, 2008 | 06:18 PM
AsianGirl007's Avatar
AsianGirl007
Lexus Diva
Whoah, I had forgotten all about the OG "pie pan" wheels on 1SC.
If memory serves, then yes that's correct.....but you might want to verify by posting this in the SC forum where most of the SC guys hang out.
Old Feb 23, 2008 | 06:23 PM
rominl's Avatar
rominl
exclusive matchup
you mean that little cover on the wheel covering the lug nuts? if so, yeah, there should be a spot where there is a little **** where you use the flat head to pop it open. at least that's my experience
Old Feb 23, 2008 | 06:24 PM
wolverine's Avatar
wolverine
there should be a tab that you can stick a screwdriver in and pop it out
Old Feb 23, 2008 | 06:28 PM
rootaku's Avatar
rootaku
pie D:
I didn't mean the lugnuts area, I meant the whole "oem" "stocktacular" wheel itself.
basically I want to know if I can get that front piece off without having to remove the wheel itself taking off the lugnuts and junk.
I'll give a few more mins to see if anyone can double verify here before moving to the sc threads
Old Feb 23, 2008 | 07:46 PM
Er, I didn't think it has wheel covers, it's a solid rim isn't it?
If so, gotta loosen the lug nuts, jack up the car, remove the wheel, in that order.
Old Feb 23, 2008 | 09:01 PM
RedPhoenix's Avatar
RedPhoenix
Im loss, are you just trying to take the wheel off? A screw driver will pop off the center cap and then you can take off the 5 lug nuts for the wheel. Dont forget to jack the car up first.
Old Feb 24, 2008 | 08:30 AM
Luxor's Avatar
Luxor
do you have hubcaps on your wheels or something? If so...In some cases you DO need to take off the lugnuts to get the hubcap off becaue some are held on by the lugnuts, in most cases, you can just use a screwdriver to pry it off at the edge, it will be easier to use two flathead screwdrivers at the same time.
Old Feb 24, 2008 | 02:09 PM
EpixINC's Avatar
EpixINC
post pictures dude... some of us are confused.
Skylar978
Mar 18, 2014 12:49 AM
TheKevin
Feb 10, 2009 11:56 AM
Dinkydow
Jan 1, 2007 02:34 PM
AmooManiaK
May 20, 2006 04:14 PM
pot_head
Wheels, Tires & Brakes Forum
Mar 19, 2002 10:28 PM
