Weird idle issue
Old Jan 28, 2008 | 12:40 PM
Curry's Avatar
Curry
CL Folding 25,000
Default Weird idle issue
EDIT
Oops, OLT you better move this. HAHA. sorry!
Ok so the motor is back together and running.
Before it used to idle at 100 @ park, reverse, neutral, 2 and L
Now it idles fine @ Park and neutral
It still idles @ 100 if I shift to drive, reverse, 2 and L
If I tap the accelerator in park like this Tap . . . Tap . . . Tap . . .
Usually on the 3rd or second tap if I continue hold the pedal the idle will drop to near 0, stutter, it wont die and the pop right back up to 1k+ depending on how hard im pressing on the pedal.
We did cap, rotor, plugs, plug wires, seafoam, TB cleaning, coolant, checked all connections and vac lines.
The only thing left to do is mess with the IACV.
I'm posting to see if I may have missed anything.
Old Jan 28, 2008 | 01:15 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Originally Posted by Curry
EDIT
MAF...........?
Old Jan 28, 2008 | 01:27 PM
Curry's Avatar
Curry
CL Folding 25,000
Originally Posted by O. L. T.
MAF...........?
Clean it? or just toss a new one on there to test it?
Old Jan 28, 2008 | 02:57 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Wouldn't want you to buy one if it is not related, but MAF's act like they are good until disconnected and the computer resets the cache of info it was previously running off of. When it has to start from scratch the MAF reveals it's true colors rather than relying on cached ecu info. That's when the fun begins and we get these "all I did was disconnect my battery and my car runs like ***" threads.
It's a possiblity.........
As far as cleaning mafs..... It's the equivalent of soldering a new tip on the end of a spark plug to get rid of gap..... you get about 8 seconds of joy.
Old Jan 28, 2008 | 03:00 PM
Curry's Avatar
Curry
CL Folding 25,000
I can borrow one from a friend or from gazi if anything, but ill try unplugging it and resetting my ECU again.
If not ill have to get that IACV off somehow and see if it needs cleaning, which im sure it does.
Old Jan 28, 2008 | 03:03 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Resetting the ECU was the problem to begin with (if it is a MAF issue).............. not going to be a solution.
Old Jan 28, 2008 | 03:06 PM
Curry's Avatar
Curry
CL Folding 25,000
Got ya, thanks.
Edit:
No go with that =/
Ill try to get my hands on another MAF tomorrow and see if that changes anything.
Old Jan 28, 2008 | 07:07 PM
Curry's Avatar
Curry
CL Folding 25,000
No luck yet. I was trying to get the IACV off. BOOO.
Im gonna try another TB tomorrow instead of the MAF.
Anyone know if the IACV can be clean from inside the TB if I take it off ??
Old Jan 29, 2008 | 10:19 AM
Curry's Avatar
Curry
CL Folding 25,000
Cleaned up the IACV this morning, no luck.
Gonna see if I can get a replacement and swap that in there.
Any other suggestions?
Old Jan 29, 2008 | 11:55 AM
Curry's Avatar
Curry
CL Folding 25,000
Just swapped another IACV in, same exact issue. nothing changed at all. I'm gonna try swapping another MAF and ECU to see if that does it. If not, im out of ideas.
Old Jan 29, 2008 | 01:42 PM
Curry's Avatar
Curry
CL Folding 25,000
Changed the ECU, same issues.
I forgot to mention. When I first got the car the rpm was @ 100 no matter where i shifted. Since doing the valve cover gaskets and tune up the only thing that has changed is the car idles fine in park and neutral @ around 700-800.
When shifting to drive, reverse, L or 2 it drops to 100 and sits there.
The car also has an aftermarket alarm wired in. Not sure if that could potentially cause any issues. It was there when i got the car, no remote or anything for it either.
Old Jan 29, 2008 | 04:22 PM
aliga's Avatar
aliga
Former Sponsor
try swapping an entire tb, could be tps, iac??
Old Jan 29, 2008 | 04:56 PM
Curry's Avatar
Curry
CL Folding 25,000
swapped an iac todd had. I guess i can try swapping an entire tb. If you have a spare laying around lemme know. The tps on the tb todd gave me was busted up.
Old Jan 30, 2008 | 04:58 PM
Curry's Avatar
Curry
CL Folding 25,000
I swapped another TPS in today and I'm having the same issue. The engine sounds normal when I shift into drive but the idle is just low. For now im attributing this to the bad cluster.
The thing where the car rpms would dip after taping the accelerator a few times still happens, but not as much as before.
I'm going to see if I can get another TPS and IACV that I know works 100% and swap them on. I'm also going to try using another MAF if I can get a hold of one. Thats about all I can think of.
Gonna hook up my emanage tomorrow and see what my rpms really are reading.
Any other tips or suggestions are welcome.
Old Jan 30, 2008 | 08:44 PM
RedPhoenix's Avatar
RedPhoenix
Unplug the MAF while the car is on. See if it changes anything?
