Coolant Reservoir
Old Dec 20, 2007 | 08:35 AM
Bob'sSC400's Avatar
Bob'sSC400
Default Coolant Reservoir
I am replacing my coolant reservoir and wanted to see if anyone had any tips or tricks that may help me through the process. Any feedback is appreciated. Thanks.
Old Dec 20, 2007 | 10:26 AM
9secCivic's Avatar
9secCivic
its 3 bolts. couldnt really be much easier.
Old Dec 20, 2007 | 10:29 AM
Luke_in_SD's Avatar
Luke_in_SD
its pretty easy, just take it off with a friend, so he can cap off the lines
Old Dec 20, 2007 | 01:21 PM
Bob'sSC400's Avatar
Bob'sSC400
thanks! I new it was easy but as with every project I get into there is always something that brings out a few cuss words...just wanted to make sure the bolts and capping the lines was the
Old Dec 20, 2007 | 01:57 PM
Luke_in_SD's Avatar
Luke_in_SD
use small sandwich plastic bags and rubber bands. they work great for temporary capping off water and other fluid lines
Old Dec 20, 2007 | 03:38 PM
over40driv's Avatar
over40driv
That reservoir is so in the way when working on the front of the engine. I wish someone would find a new out of the way location for it.
Old Dec 20, 2007 | 05:44 PM
over40driv's Avatar
over40driv
I used to think that a catch can was an aftermarket radiator reservoir which you could relocate. Then I read a post about it having to do with pcv duty on a turbo application.
Old Dec 21, 2007 | 12:05 PM
Bob'sSC400's Avatar
Bob'sSC400
got it in last night with no problem...took all of 15 minutes....thanks.
Now I need to replace the power steering pump, fuel pump and fuel filter...
where is the fuel pump located? Anyone?
bcorey
Dec 31, 2016 06:34 AM
Lukas99GS
Mar 12, 2015 08:50 PM
333arod333
Aug 11, 2013 11:30 AM
Jmai22
GS - 1st Gen (1993-1997)
Feb 20, 2003 11:33 AM
The Ikon
May 31, 2002 02:04 PM
