my build ( in progress )
all started when i spun a rod bearing in my 1jz
new oem toyota 2jz-gte short block
new oem toyota oil pump
shimmed oil pick up
every gasket replaced
arp head studs
oem toyota head gasket
port and polish head
crowler valve springs
HKS 272/264 cams
adjustable cam gears
T4 exhaust manifold
tial 40mm wastegate
greddy t78-33d
all vac hoses are ss
mvp motor sports top feed fuel rail
RC 800cc injectors
veilside replica intake manifold
80mm throttle body
dual ssqv bov's
2jz wiring harness
aem ems
aem 3 bar map sensor
24x12x4 inch front mount
2.5 inch hot side intercooler piping
3 inch cold side intercooler piping
areomotive feul pressure regulator
and much more i know i am forgetting a few things that i cant remember.
i found some free time tonight....
finished the motor
bolted the motor to the car
shimmed oil pick up
arp head studs
HKS 272/264 cams
T4 exhaust manifold
tial 40mm wastegate
greddy t78-33d
RC 800cc injectors
80mm throttle body
dual ssqv bov's
2jz wiring harness
aem ems
finished the motor
Nice job Matt, next season is going to be crazy with all the boosted SC's around here. I will need to go single sooner than I planned lol.
yeah it was a total accident when i went to Toyota and ordered a 2jz-gte short block assembly
read the main post before you reply.thanks bro
why??? are you trying to keep up with the big dawgs now rofl i thought you were going to rock the stock twins for as long as you could
i think (val)(sp) has a faster sc then me
i offered to help Fonzo with his car but he never said anything back i guess he has it covered on his own
My gta just spun a bearing, it must have worn the main down about 1/8" crazy!
