Help - Boosting Problem
Old Oct 16, 2007 | 06:02 PM
Shinbone's Avatar
Shinbone
Registered User
Default Help - Boosting Problem
Spec - 99 Sc300 with GTE and BL Auto 3800 Stall, BL67DBB
Ever since I had the stock twins, the boost was very unpredicable. When it was stock I thought my vacuum routing was bad so I replaced the turbos with single.
Still the same thing, the boost some days hit 10 lbs, than 15lbs, (where I had it set with EVC - checked all the vacuum lines and replaced them all just incase pin holes) but still some days it will hit 18 lbs than 10 lbs.
Could it be due to my stock(SC) rear end??
I have checked and tighted all the piping. Any other ideas? Thanks in advance.
Old Oct 16, 2007 | 06:08 PM
Rising_Sun's Avatar
Rising_Sun
Have your intercooler pressurized for leaks. Check your intake manifold, a bad gasket can cause boost loss.
Old Oct 19, 2007 | 06:32 PM
Shinbone's Avatar
Shinbone
Registered User
Thank you for the input, i was able to re-route the vacuum lines and just got it running correctly. Thank you.
fried_rice
May 15, 2012 01:28 PM
INTIMAZY
Jan 8, 2012 03:37 PM
Justin2JZ
Performance
May 31, 2011 08:27 AM
tranii2
Aug 3, 2008 01:36 PM
VJ RC51
Mar 19, 2006 10:22 AM
