Boost Leak, IACV and Intake Manifold
My IACV has hairline cracks from age and when I pressurized the system it is leaking. The car has always had a hesitsation problem, which I assume is a result of this problem. I've searched and haven't seen anyone with this issue. Seeing how my car is a dedicated track car I really don't care about the hesitation or idle too much, but I don't want boost leaks obviously.
I'm planing on gluing the plastic part to seal it with something of the like of fiberglass resin. Anyone have thoughts on this?
Also my intake manifold is leaking at the lower runners. I put as new gasket and it still leaks. Should I use FIPG and the stock gasket, just FIPG gasket, or try another new oem gasket.
The car hits 18lbs fine, but obviously it will perform better with no boost leaks. It leaks all air out within 5 seconds of 25lb pressure test.
Thanks
Thanks
Thanks, I'll try the copper spray and a new oem gasket. I didn't torque in sequence or to spec so that may be another reason for the leaking. Maybe I'll be able to find a good used IACV, for cheap. I don't want to pay $300 for a new one, when the car hardly ever sees below 4,000 rpm, lol.
I got the copper spray and put the new gasket on. The old gasket, prior to the new one had kind of melted on the lower runners and intake manifold, I'm thinking that's what was causing the leak. I scraped off all the material and sprayed 3 coats of copper sealant.
Good idea, I'm sure it's not working as it is. So not having one at all can't be that much worse. I have no A/C, progressive powersteering, or electronics that will mess with the idle anyways. I'll go cut one out real quick, and take it for a drive.
ToyotaFanz
21
Feb 13, 2018 04:50 PM
btcoop
Mar 24, 2013 08:06 PM
fried_rice
May 13, 2012 03:59 PM
