boost leak?
Old May 27, 2011 | 05:13 AM
Justin2JZ's Avatar
Justin2JZ
Default boost leak?
Yesterday on my way to work, I decided to set my boost to 25lbs. I did a wot run and it didnt go past 20lbs and then it dropped to about 10lbs, does anybody know the possible cause of this?
Old May 28, 2011 | 01:51 PM
smuv gs3's Avatar
smuv gs3
Check all your couplers make sure they are tight and get a boost leak and vaccum leak test. I had the same problem and even though my couplers were tight the couplers themselves were shot
Old May 28, 2011 | 03:26 PM
JeffTsai's Avatar
JeffTsai
You could have a rip or tear in the couplers. I fabricated a custom pressure testing tool to check the IC piping for leaks. I TIG welded my tool from aluminum pipe, but you can probably fab up something similar with some PVC pipe from Home Depot.
Old May 31, 2011 | 08:27 AM
Justin2JZ's Avatar
Justin2JZ
You guys are right, the guy said that there was a huge rip in the couplers. She's holding boost fine now.
INTIMAZY
Jan 8, 2012 03:37 PM
broda805
Sep 1, 2011 10:20 AM
Superjatt
Mar 12, 2011 12:19 PM
1JZ300
Dec 20, 2006 02:46 PM
