sc400 hid kit install help
Old Oct 15, 2007 | 07:13 AM
anhion's Avatar
anhion
Default sc400 hid kit install help
so i got an hid kit to install on my car
it wont power on.
it's all plug and play
do i have to remove day time running lights?
if so how can i disable them. can i just remove a fuse or just unplug them from harness?
Old Oct 15, 2007 | 07:25 AM
soarinhigh's Avatar
soarinhigh
what brand is it? I got one off of ebay and it wouldn't work all I did is plug in the harness backwards...the one where the kit connects to the car....I just turned the plug around and it worked...oh yeah, mine was made by "pilot"
Old Oct 15, 2007 | 11:04 AM
Black_SC's Avatar
Black_SC
its most likely that the positive and negative is switched on the part that connects to the headlight plug...happened to me...i just switched them back around and bam they worked.
Old Oct 15, 2007 | 11:59 AM
Jonathan o's Avatar
Jonathan o
^^^^^^^^^^^^^^^^^ What they said.
Old Oct 15, 2007 | 04:11 PM
tuterz's Avatar
tuterz
what they said!! .. happened to me too.. blacksc fixed mine..
Old Oct 15, 2007 | 06:53 PM
anhion's Avatar
anhion
thing is my harness is made for a 9006 bulb so its all plug and play. if i reverse the harness it wont fit on correctly.
ummm i even tried to take out the day time running light bulbs and no luck.maybe i just got a dud.
i will try it again see whats up. thanks for the help and if anyone else has suggestions please let me know.
Old Oct 15, 2007 | 06:54 PM
anhion's Avatar
anhion
oh yea not sure the brand its an ebay kit.
so many companies making these now a days. it sells for dirt cheap too
i guess u get what u pay for? lol
Old Oct 15, 2007 | 07:14 PM
Baoser's Avatar
Baoser
umm...it will fit on correctly...i used to work at a shop and all we did was Angel Eyes and HIDs. Some of the ballasts have reversed plugs...don't ask me why, iunno, manufactures are dumb...the normal ballast plug is typically for a 9006 application, then you have the harness that plugs into a H1,H3, H7, etc etc
Old Oct 16, 2007 | 06:11 AM
soarinhigh's Avatar
soarinhigh
just reverse it...I bet it will work.
Old Oct 16, 2007 | 06:25 AM
tuterz's Avatar
tuterz
just.. use something pointy.. and.. poke it in the harness to remove the progs.. them reverse them.. if you look at the wires that come from your stock harness and.. the hid kit plug in.. the positive and negative is switched around... it'll fit.. if you reverse the progs.. not turn the plug.. if you're not getting what im saying.. just cut the wires and switch them.. that would work too..
Old Oct 16, 2007 | 06:54 AM
RedPhoenix's Avatar
RedPhoenix
did this on my german bmw hids. its just the way lexus made the plug.
Old Oct 16, 2007 | 06:56 PM
dopsc's Avatar
dopsc
I had the same problem, just switch the wires by looking inside that male connector and moving the clip aside then the wire will come out and swap them. So switch the negative to positive and vice versa.
Old Oct 16, 2007 | 07:11 PM
Black_SC's Avatar
Black_SC
you gotta take the lil pos and neg rods out the plug thing....and switch them manually....pretty simple and takes about 5 min.
Old Oct 19, 2007 | 11:48 PM
anhion's Avatar
anhion
so i just switched the harness doesnt clip in but its reverses the polarity
it works now
thanks guys.
Kon7827
IS - 1st Gen (2001-2005)
Jan 8, 2015 06:50 PM
Carbon J
Feb 8, 2010 01:53 PM
dzdg8018
Lighting
Jan 28, 2009 08:46 AM
HoustonIS
Sep 30, 2008 04:53 AM
TurboLexus
Lighting
Oct 1, 2005 03:10 PM
