Mechanical Engineering Paper...
i want to go into mechanical engineering and i need a topic having to do with motors and the topic must have a controversy.
for my physical project iam going to make and weld a custom CAI and Possibly a exhaust for my sc. thank you for any help.
You could also do a cost-benefit analysis of various turbos (and the required supporting mods) on the 2JZ-GTE to determine the true point of dimishing returns for the engine.
Another study could be on the 1JZ vs. the 2JZ swap on an SC300: which makes more power for less money. Examine set-ups and settle the debate as to the power level at which the 1JZ becomes cost-ineffective.
You have a number of guys on these forums and Supraforums that would share set-ups that had and the power they were making. You could run a cost-benefit anazlysis and determine the optimal value set up on the 1JZ and the 2JZ and establish the power level at which the 1JZ becomes more expensive (in the long run) as compared to the 2JZ.
There is definitely controversy, and you would definitely not be short on information. To make the paper more technical in nature, you could perhaps explain why yoru findings have occured within the context of the various strengths and weaknesses of the individual engines: displacement, head structure, cams, redline, etc, etc.
that really sounds like a exciting topic. but i only know 1 person with a 1jz and hes putting it in a MKIII supra. but i dont think that would matter. i dont mind using that one but that kind of sounds like something in the long run. but so far thats on top of my list. thank you. Blizzy
Now i have to find a mentor that knows all about this kind of stuff.
More suggestions are still welcomed.
sooo anyone have a suggestion on a controversial topic on anything having to do with mechanical engineering?
It is too bad your teacher is not more willing to let you go out and do a paper on what you are interested in. The 1JZ vs 2JZ would have been a pretty sweet paper.
What class is it for? (would help in the suggesting of topics)
but then he ruined my day.
its for senior seminar.
yup. im still in high school.
i dont know what states have senior seminar but ill tell u about it if u dont know what it is.
