help on finding a post please
Old Sep 3, 2007 | 09:33 AM
thebadz32's Avatar
thebadz32
Default help on finding a post please
ive been searching for the diy on how to make ur turning assist lights come on with the flick of a switch and i cant seem to find it can someone help me out please thanks in advance.
Old Sep 3, 2007 | 09:40 AM
JspecSC3's Avatar
JspecSC3
You must be referring to the cornering lights on the 92-94 SC. There are a couple of DIYs out there on how to convert them to fog lights. I did one myself. You can also check out intellexual.net for the perfect DIY on how to make those turn on with your headlights. Since you actually did try to search I'll throw in a freebie.
https://www.clublexus.com/forums/sho...ght+conversion
Old Sep 3, 2007 | 09:44 AM
thebadz32's Avatar
thebadz32
thank you very much, i hate doing wireing work what way would u find to be the easyist?
links arent working
Old Sep 3, 2007 | 09:59 AM
JspecSC3's Avatar
JspecSC3
Try the link now. Also if you really want to use the switch you can do it the way I did it. Its much easier.
Old Sep 3, 2007 | 10:01 AM
thebadz32's Avatar
thebadz32
thank u very much
Old Sep 3, 2007 | 10:25 AM
Blizzy's Avatar
Blizzy
that is really fantastic. nice mousework.
Old Sep 3, 2007 | 10:54 AM
Baker's Avatar
Baker
For safety and to prevent the switch burning out down the road, I would recommend a fuse directly at the battery on the + terminal (if there were to be a short on that red wire it would burn all the way to the battery from the short) and the use of a relay as shown in the first diagram of this thread. If you dont use a relay it puts the amperage load through the toggle switch which is made to handle minimal current. The relay will provide better voltage to the lights (which in turn gives you brighter lights) and not have to worry about a small cabin fire.
Old Sep 3, 2007 | 12:18 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Beat me to it. Throw a relay in there since the lights can be turned on for long periods of time driving. Too much heat on the wires otherwise, especially if you use upgraded bulbs.
Old Sep 3, 2007 | 02:16 PM
2JZ_SC's Avatar
2JZ_SC
You can ground it to the body instead of the battery.
SteveORT
Jul 1, 2013 08:14 AM
VNN326
Oct 30, 2007 04:11 PM
Franklin_
Mar 22, 2007 10:23 PM
Sweetser
Lighting
Jul 13, 2006 01:43 PM
