Turn Key Solution.
Old Jun 20, 2007 | 01:03 PM
  #46
dejacky's Avatar
dejacky
Originally Posted by YumaSC300
But will the cost for a full R514 swap end up being close a 6 Speed swap?
No, it shouldn't. Of course, if you overpay for the R154 swap, it won't matter. The nice thing with the R154 swap is you don't have to change out your rear diff because the gearing matches. Also, R154's are hella cheaper (and easier to attain) than getrag transmissions.
Old Jun 20, 2007 | 01:34 PM
  #47
DasBach's Avatar
DasBach
4400 for the Getrag from Carson. I tried searching a few minutes ago but no luck, what is the about cost for a full R154 swap?
Old Jun 20, 2007 | 01:56 PM
  #48
ISC400's Avatar
ISC400
FYI: Theres a Soarer R154 on eBay right now
Old Jun 20, 2007 | 10:19 PM
  #49
DasBach's Avatar
DasBach
Dunno, gotta think about it lol. Does the 6 Speed even save much in gas?
Old Jun 20, 2007 | 10:41 PM
  #50
dejacky's Avatar
dejacky
it's not so much rpm that kills gas mileage as it is ignition timing. like i told u earlier, i got 25mpg highway mileage on my original na-t setup and my cruising rpms were 2800-3100rpm. If you're not pushing the throttle pedal down a lot at those rpms, you'll be fine. If you go wide open throttle at the same rpms, you will burn a lot more fuel. The beauty of AEM EMS, is you can customize all of this, so my point is your gas mileage will be perfectly fine with R154 and your sc300 rear-end. With the money saved, you can put a nice limited slip differential in your SC300 rear pumpkin too!
Old Jun 21, 2007 | 10:21 AM
  #51
DasBach's Avatar
DasBach
I guess I'll work towards an R154 then. I got into a car accident yesterday so its down time for the shop... Kinda sucks.
NR04
GX - 1st Gen (2003-2009)
Oct 12, 2021 01:33 PM
TonyH
Jun 24, 2013 07:00 PM
jknguyen80
Jul 22, 2012 04:49 AM
jknguyen80
Jan 22, 2012 12:23 AM
LEX012006
Feb 16, 2008 05:32 PM
