Heat coming from ebrake
Old Apr 24, 2007 | 02:10 PM
Pentium's Avatar
Pentium
Default Heat coming from ebrake
Hello everyone, I just jointed this forum. I have a problem with my SC400 and I need yall help. There is a lot of hot air coming from the ebrake boot, it so hot that I have to keep A/C on most of the time. I have already check for exhaust/cat leak but I could not located where all the heat coming from. Please help me out. Thanks
Old Apr 24, 2007 | 02:51 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
Heat from the transmission tunnel. That simple.
Your solution would be to remove the center console and add additional heat reflective material.
Old Apr 24, 2007 | 08:48 PM
omgitsroy's Avatar
omgitsroy
Old Apr 24, 2007 | 09:55 PM
jacobzking's Avatar
jacobzking
sounds like your cat is clogged an over heating, remove and inspect the cat converter.
Old Apr 24, 2007 | 11:44 PM
vinh's Avatar
vinh
Originally Posted by omgitsroy
i have this same problem too, its just heat coming from the transmission. If its as bothersome as you say it is just simply do as stated above.
Old Apr 25, 2007 | 07:33 AM
Pentium's Avatar
Pentium
Thanks, I will try that over the weekend. Is there any DIY tutorial on this site showing how to remove the center console? I search but the only thing come up is the door panel.
oldManTan
Apr 15, 2014 05:10 AM
exiakira
Mar 17, 2013 09:14 AM
simonknigt
Jul 10, 2010 10:03 PM
CCC-TT
Jul 23, 2007 06:12 AM
99LexusES3
May 17, 2004 06:18 PM
