MKIII Supra LSD?
Old Apr 21, 2007 | 11:21 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
Default MKIII Supra LSD?
Can it fit on a Sc400? 92-97 SC400 8 cyl (3.92 ratio). Supra Automatic Turbo : 3.909 (LSD clutch type), 5spd turbo: 3.909 (LSD clutch type) depending on year. Has anyone done it?
Old Apr 22, 2007 | 04:50 AM
Blizzy's Avatar
Blizzy
It is certainly not a bolt on.
Run a few searches: the MKIV Supra LSDs that are not for the 6 speed bolt up. The other option is to drop a TRD or Kaaz unit into your stock differential housing.
Old Apr 22, 2007 | 03:10 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
I have a LSD from a MK3 Supra i just want to know if it fit on my car? i don't want to take the diff off my car an it don't fit so I'm asking has anyone did this diff swap before?
Old Apr 22, 2007 | 09:03 PM
Blizzy's Avatar
Blizzy
as far as I know, no one has done this swap because it doesn't work. If you take off your stock diff, you will not be able to bolt up the MKIII diff.
Old Apr 23, 2007 | 01:25 AM
Sc1UZ-FE's Avatar
Sc1UZ-FE
how about just the LSD not the housing?
Old Apr 24, 2007 | 03:52 AM
Teflon Don's Avatar
Teflon Don
wont work. The diff is too small.
Old Apr 24, 2007 | 03:56 AM
Teflon Don's Avatar
Teflon Don
The one on the left is a soarer open diff. On right is the MK3 supra LSD.
Ken'sGS300
GS - 1st Gen (1993-1997)
Nov 22, 2010 10:58 AM
stevechumo
Jan 18, 2009 05:24 PM
modifyd
Performance
Feb 21, 2006 07:56 PM
TLW
Performance
34
Mar 21, 2005 09:33 AM
CDALTON
Jul 19, 2001 05:38 PM
