If i align my lights using the water bubble level it points up in the air. Has my sc400 coil springs lost their tension causing sagging in the front. Any help would be great. I have used both the advance search and normal such to know avail. Thanks
the manual says fill your tank up with gas and have someone sit in the drivers seat to emulate daily driving, then get on a level surface and do it that way....
my suggestion it drive up to a wall about 10 feet away on a level surface and just level the beams on the wall, the levels on the headlights are pretty useless IMO
Thanks Guy's, I will start with your recommendations. It is also obvious that I definately have to remove the headlights for a good cleaning. After reading all the post, I'm almost sure that will help as well. I have a 93 and 95 sc4 that my daughters drive. These have been the most reliable cars that they have driven. Just want to keep them safe.
