How do you lube the door hinge?
Old Dec 30, 2006 | 05:14 PM
omarkamal's Avatar
omarkamal
Question How do you lube the door hinge?
Hi I searched several different ways
but no tips on how to apply the white lithium grease to the door hinges.
It seems that the pins and mechanisms are sealed, what do I apply the grease to - is there something I have to take off or loosen so I can get the grease into the mechanism
Any tips on this?
Old Dec 30, 2006 | 05:22 PM
over40driv's Avatar
over40driv
I asked the same question about 3 months ago, and got very little response, the more your cans spray preasure, the more it will force it into the hinge.
Old Dec 30, 2006 | 07:34 PM
96gti2.0t's Avatar
96gti2.0t
i just used spray lube seems to have worked fine for me
Old Dec 31, 2006 | 03:43 AM
DriftNsc3's Avatar
DriftNsc3
How about getting a needle and inject it into where ever it needs to go? something like they do with turkeys,lol. Seriously though if you get a big enough neddle it should work.................maybe?
Old Dec 31, 2006 | 10:41 PM
JohnEd's Avatar
JohnEd
Default door lube
Guys,
My door, 93sc400, started creaking very badly. I looked all over for lube holes and came up zilch. The lube you want is the best stuff in the WORLD by LUBRIPLATE. Get the outdoor chain and cable lube and penatrating oil. I put this on my LandCruiser winch drive chain out on the front bumper. Two years later the chain was supple and rust free. Get the part about front bumper? I live in Eugene, Orygun and it rains a lot. Best oil I have ever even heard of. The loggers use it for their equip that sits outside all year. Imagine!
The part of my door that was making noise was the door stop assembly. It is a curved stamping that has a rod running back and forth inside. The cup of the curved piece faces away from you so you can't spray stuff INTO it. The lube comes with a flexible spout so you can twist it so it fires in a U and get it inside the assenbly. White lith grease would work too but you would have to bend a small brush in a U.
Good luck
John
Old Jan 1, 2007 | 01:16 AM
DriftNsc3's Avatar
DriftNsc3
^^^vERY GOOD ADVICE!
Old Jan 1, 2007 | 02:10 PM
bizzy928's Avatar
bizzy928
I use heavy duty ball bearing grease. It comes in a squeeze tube and is green in colour. Temperature does not affect it, and it goes on THICK. I just apply it generously with my hands (use gloves) and try to rub it in. Using your door in the future will in turn help lube the hinge more.
Old Mar 12, 2017 | 07:16 PM
Svenster12's Avatar
Svenster12
Yesterday, I followed the advice from a posting on this site and it worked perfectly. Remove the "half collar", that's held in place with two small bolts, that take either a Phillips screw driver or better yet, a 10mm socket. One is a ***** to get out, then back in. Be careful not to lose the ball that holds the door open in two positions. Clean up everything and even grind out/polish where this ball rolls and you should be good for several years. The wear I saw and shined up didn't look like the problem, but evidently was. You'll spend most of your time messing with the internal bolt. Get some sort of magnetic swivel 1/4" drive, will help considerably. Good luck!
Old Mar 13, 2017 | 12:49 PM
Returd's Avatar
Returd
that sounds good for the door stop, but the hinge pins themselves can't be lubed (in my opinion). Any external application intended to lube the pins/bearings is wishful thinking.
GS350Lexus
Sep 4, 2021 09:37 AM
Squirrel85
Mar 25, 2016 02:59 AM
plovell
Jan 13, 2016 10:14 PM
Gs3500
Jul 9, 2015 09:13 PM
Lexscme
Aug 27, 2009 02:15 PM
