question with cross drilled brembos
Old Sep 3, 2006 | 10:03 AM
scfourhun's Avatar
scfourhun
Default question with cross drilled brembos
ok guys, here it goes, i just ordered some tt calipers with brembo cross drilled rotors, goodrigde lines and hawk pads everything used except for pads and lines, all for the front. upon receiving it, i was very pleased with everything. but i went onto the brembo site and noticed the tt front rotors are part number 35571, the rotors are slightly used and in a used brembo box that reads part number 35572, which are the rear rotors. now my question is; do brembo stamp their part number in their rotors? the part number inside the rotors are neither the front or rears. it could of been that he sent a brembo box with different brand rotors? or he sent the front rotors with the rear brembo box. all i know is that i measured the rotors and they're 12 3/4" in diameter.
anyone have tt brembos cross drilled in the front that could help me?
Old Sep 3, 2006 | 11:41 AM
scfourhun's Avatar
scfourhun
please....anyone?
Old Sep 3, 2006 | 11:47 AM
goldlifter's Avatar
goldlifter
a lot of companies buy brembo blanks and cross drill/slot them themselves....perhaps there was a mixup when they put them back in the box(shrugs)
Old Sep 3, 2006 | 12:33 PM
lfrers's Avatar
lfrers
is was around 13 inches or so. does yours look like mine?
Old Sep 3, 2006 | 12:46 PM
scfourhun's Avatar
scfourhun
looks like you have the 2 piece with slotted and cross drilled design. i only have the 1 piece cross drilled. mine are one quarter of an inch shy of 13". thanks for your help...anyone else can provide som numbers??
Old Sep 3, 2006 | 12:51 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Don't worry about the numbers, you likely bought blanks that were pre-drilled. I'm assuming they are silver? If so, they are blanks and brembo numbers won't apply to them.
Here's mine:
Old Sep 3, 2006 | 12:52 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Attached Thumbnails question with cross drilled brembos-attachment-1.php.jpg
Old Sep 3, 2006 | 08:45 PM
scfourhun's Avatar
scfourhun
this is one of my rotor...no where does it say brembo...just a few numbers on the inside part. do brembo stamp their names in their rotors?
Old Sep 3, 2006 | 10:48 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
mine are stamped as you can see, but i dunno if it's all like that.... you'd think so.
Old Sep 4, 2006 | 07:45 AM
scfourhun's Avatar
scfourhun
i have another question, like i previously mentioned, i have the tt calipers, hawk pads, rotors and s/s lines to put into my sc, question is, do i need anything else from the supra to mount in the sc, or can i use everything from the sc to properly install?
Old Sep 4, 2006 | 03:25 PM
Sweetser's Avatar
Sweetser
Isn't the drilled rotors bad to get?
I always read suggestions of just getting slotted.
Old Sep 4, 2006 | 08:41 PM
scfourhun's Avatar
scfourhun
wrong, drilled are good, they dissipate and transfer heat away from the rotor, slotted on the other hand causes premature pad wear ...can anyone answer my previous question...aside from what i have, do i need anything else to mount these tt calipers, like, can i use the sc brackets??
Old Sep 4, 2006 | 09:35 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
actually, there are arguments both ways... slotted rotors allow for self cleaning of the pad at the expense of increased pad wear... drilled rotors just plain break... not brake, break... there are certain ones (porsche) that actually have the holes cast in the material leaving a stronger rotor, not a weakened rotor with holes in it...
in the real car racing world, we run normal, flat brakes, nothing special... I have seen too many broken in half cross drilled rotors in my time... so, unless of course you can afford the porsche / exotic stuff, get normal brake rotors, but keep in mind, if you do, you'll be running through brake pads like you wouldn't believe if you really drive the car...
for street use, I like the slotted, as it keeps the brakes from squealing, and I can live with pad life of around 20k miles...
on the track, it's porterfield cryo-treated, standard flat brake rotors and nothing else...
Old Sep 10, 2006 | 08:18 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
You are good to go with what you have. TT Calipers bolt right into the existing holes of the SC3 (d.k. on SC4, probably the same). You will need to cut/bend the brake dust shield. It will be obvious once you put those big rotors there what to do.
The S/S lines can be a true PITA. Be careful with the threading, its a challenge.
jamesrg87
Apr 20, 2016 04:04 PM
vscout
Suspension and Brakes
12
Jul 18, 2015 11:23 AM
vwynn
Mar 15, 2009 08:28 PM
spxChrome
Feb 28, 2003 05:59 AM
