wheel adapters?
Old May 14, 2006 | 06:57 PM
blknfury's Avatar
blknfury
Default wheel adapters?
anyone know where to get a 5x114.3 to 5x100 adapter for my sc? got these rims at good price, but bolt pattern is 5x100.
Old May 16, 2006 | 09:40 AM
jibbby's Avatar
jibbby
Banned - could not follow forum rules
Try Ebay, if you want a 3/4" pro adaptors with rim hub fit (perfect for the rear wheels - " strength") I got an extra pair and paid $160 for both, didn't need them on a brake swap but I do need a good offer to give them up..
Old May 16, 2006 | 09:53 AM
jibbby's Avatar
jibbby
Don't use these adaptors on the rears if your car has some power....The big adaptor in the pic failed a year ago and sent my rear tire flying into some ones front yard while going about 40mph ...I then road my rotor to a stop..I am lucky as it could have been alot worse, but what a spark show I made, better then most fireworks... I wish I would have saved the broken adaptor but I trashed it...
Anyway, just be careful when using spacers and or adaptors, and always make sure you have 6 full turns on your threads/lug nuts when using spacers on the rears...Longer studs are needed on these SC's when using over 1/4 spacers...
Old May 16, 2006 | 01:52 PM
blknfury's Avatar
blknfury
what material is the spacer made of, aluminum?
Old May 16, 2006 | 01:54 PM
jibbby's Avatar
jibbby
Yes alluminum as most thick ones are.......Here is another pic...that little lip you see on the adaptor makes all the difference for strength... You also won't find any 3/4" inch adaptors anywhere...Most makes start at 1"....If you want the name of the business that makes the performance adaptors and spacers in Los Angeles Ca. I have to dig it up it has been a while....
Old May 16, 2006 | 02:15 PM
jibbby's Avatar
jibbby
These 1/4" rear wheel spacers were made for my Sc400 also for $!40....These are the thickest you should go with out changing out your wheel studs for longer ones.....
Old May 16, 2006 | 05:16 PM
blknfury's Avatar
blknfury
is it $40 for the pair or just one?
Old May 17, 2006 | 11:25 AM
jibbby's Avatar
jibbby
Custom wheel adaptors were $160 for the pair... You can get cheep ones on ebay for $40 or at performance wheel shops...
FabianS
NX - 1st Gen (2015-2021)
19
Sep 8, 2017 02:10 PM
l3lkis250
Sep 19, 2008 05:03 AM
Noypi
RX - 1st Gen (1999-2003)
Nov 8, 2007 07:39 PM
sc400 2nv
Wheels, Tires & Brakes Forum
May 24, 2007 02:38 AM
Terp1962
Sep 8, 2003 05:34 PM
