help!!
Old Feb 12, 2006 | 07:54 PM
lexony's Avatar
lexony
Default help!!
Hey all I have a 95 sc400 and have been having an issue as of late, while drving the car seems to want to die but dose not, I got the idiot lights to come on but it did not die all the way, like it is shutting down. Also when you are driving at night and depress the brake the headlights almost go out!(somtimes). I am going to autozone to have the charging system checked, just wondering if any one had any ideas. Thanks Ryan
Old Feb 12, 2006 | 11:00 PM
lexony's Avatar
lexony
Come on help a newb out!!
Old Feb 12, 2006 | 11:11 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
same problem as the other 200 threads posting the same thing you should have found in search
Alternator and/or ground problem. check ALL cables, clamps, connections relating to ground in the engine bay.
Old Feb 13, 2006 | 06:34 AM
bigmalik00's Avatar
bigmalik00
I had to do the same thing last week... I had to change out the battery clamps(old ones corroded) I got mine from the toyota dealership $15 each...and I also brought a cheap battery from walmart.
Old Feb 13, 2006 | 08:52 AM
lexony's Avatar
lexony
Thanks I will try that!!
Old Feb 13, 2006 | 08:54 AM
lexony's Avatar
lexony
Ya, and how would I word a search like that?
Old Feb 13, 2006 | 09:10 AM
G Star's Avatar
G Star
Well, your battery seems to be having it's power drained so...
...maybe battery and draining would help.
https://www.clublexus.com/forums/sho...ttery+draining
I don't understand why people like to vicitimize themselves when they're told to search. It isn't a hard task to do. Type some words, click some links, read some threads and you're good. Why make it sound like you're going to die if you try a little search?
Old Feb 14, 2006 | 07:16 PM
lexony's Avatar
lexony
hey all got it fixed!!! With my POS its something every week, and just FYI for "some" I did do a search!!! Later
Old Feb 14, 2006 | 07:34 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
How about sharing what the fix was so others can learn too
Old Feb 14, 2006 | 07:58 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
one of the above?
Old Feb 14, 2006 | 09:02 PM
lexony's Avatar
lexony
combo of bad batt., bad connections, and of all things the MAF was bad!! Thanks for the help in getting started guys!! Thanks Ryan
diehardlex
GX - 1st Gen (2003-2009)
Aug 10, 2015 12:30 PM
Carfreak70
Jan 22, 2008 08:25 PM
micell2
Feb 22, 2005 10:40 AM
jcboiz
Aug 8, 2002 06:54 PM
lionj
Feb 22, 2002 06:03 PM
