How does one determine if a wheel clears a BBK?
Old Oct 14, 2005 | 08:11 PM
MongooseGA's Avatar
MongooseGA
Default How does one determine if a wheel clears a BBK?
I know it's gotta be a 'high disk' wheel, but how can I tell by looking at it? Or can I?
For example:
A 18"x9" wheel with a +45mm offset- seems wide enough, but I don't know how to tell if it will clear or not.
I tried searching, but the results were kind of overwhelming.
Old Oct 14, 2005 | 09:31 PM
kietlander's Avatar
kietlander
what wheels are they?
Old Oct 14, 2005 | 11:15 PM
Minuet's Avatar
Minuet
Stoptech has a template on their site.
http://www.stoptech.com/tech_info/wheel_fitment.shtml
Old Oct 14, 2005 | 11:20 PM
MongooseGA's Avatar
MongooseGA
Thank you.
Old Oct 15, 2005 | 02:03 AM
Neo's Avatar
Neo
The One
Just keep in mind that this is for their BBK setup only. A number of the other BBKs require more space. If the wheels do not accomodate the StopTechs, they will not work with the others like AP Racing, Supra TT, LS, ...
Old Oct 15, 2005 | 11:13 AM
Minuet's Avatar
Minuet
Neo is correct. That template is for the Stoptech BBK only. I have found the Stoptech BBK requires the least amount of clearance of all the BBKs. So if you can’t clear the Stoptech then all the others , Supra, Ls400, Brembo, Rotora, etc will not clear.
Old Oct 15, 2005 | 11:32 AM
Neo's Avatar
Neo
The One
Actually, the Rotora 4-piston caliper requires less than the StopTechs.
Old Oct 19, 2005 | 10:44 PM
97Soarer's Avatar
97Soarer
what an intuitive idea (templates). which one is for the sc??
SC Series 1992-2000, Front brake upgrade 332x32
SC Series 1992-2000, Front brake upgrade 355x32
what does the 332 vs 355 stand for?
Old Oct 19, 2005 | 10:57 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
That's the size of the rotor in mm. 355mm is the bigger (14") rotor.
Guitars4ME
Dec 20, 2017 05:07 AM
black_gs99
Wheels, Tires & Brakes Forum
Jun 26, 2008 02:21 PM
kevs98GS4
Suspension and Brakes
Nov 3, 2007 02:44 PM
Boostage
Nov 12, 2005 08:58 PM
BLK13X
Sep 23, 2005 02:06 PM
