SC300/400 Replaced Headlights and Blue Cut-off line
#92
Originally Posted by IronCobra
mmmm purdy!
#93
One headlight is brand new, the other is old, can you guess which one is which?
BTW my camera made one light look a slightly different color, but this isn't visible in person... The bulbs are identical...
#94
#95
Sorry, i'm at work now, and will probably put the other light back in tomorrow (sold my old ones)... Though i think it does show how close the two are in performance... (take a guess?)
#96
#98
Has anyone looked inside where the bulb goes in? I just bought a new one off ebay for the drivers side, have not installed yet, but out of curiousity, you can see the _/-- cutoff line in there...wonder what the pre-2002's look like?
My 1995 headlights are a joke, with zero cutoff lines, worthless in oregon rain! can't wait to get this one installed, and have another on the way!
THANKS for this discovery!!!
#99
Installed drivers side today, aparently the passenger side was replaced at some point in the past. Now both lights have a clean cuttoff, verymuch a worthwhile upgrade for those who have the older style lights!!
#102
I was wondering from you guys who are using the HID's, What style bulb you are using in regards to the base type?
I've been using a kits from infinity q45, and i made up some bull***** socket brackets to mount them. How are you guys doing it? Keeping it waterproof and sealed.
What's your source?
What's your source?
#103
What's your source?
What's your source?
#104
I got my recommendation from xenondepot.com for about $400, 4300k. Best thing about it was that the color temp is perfect white/purple but very bright with the new headlight on. I noticed internally that the cutoff inside of the lense is very very slightly, it slopes as a curve then /-- Hard to explain, but there is a difference, that and I'm sure the lens itself is much much better.
#105
Rebase the bulbs huh?
This is done by turning the bulb in a lathe to remove material so that an aluminum bracket will fit the bulb and match the socket? Is this correct?
Not to highjack a thread or change subject, just thought this would be good info for us, along with the recent knowledge of the 99 and newer headlight housings. This is going to be a winter project for me for sure.
