1JZ power
Old May 4, 2005 | 10:54 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Default 1JZ power
I tried searching but cant find anything. Whats the most hp you can get out of a 1JZ? I've been hearing about all these people switching to 1JZ and have been curious about the potential. Everyone knows 2JZ GTE can make over 1000. My question is, with the right turbo and other upgrades, whats the most power the 1JZ can make? I might just go with the 1JZ because 2JZ will take years to save up for and mod.
Old May 4, 2005 | 11:36 AM
mteele's Avatar
mteele
CL Folding 10,000
There is a 1JZ in Georgia making over 900, and I have heard of others over the 1000hp mark.
Old May 4, 2005 | 11:45 AM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Damn. No wonder you went with it. WHen do you plan on upgrading the turbo?
Do you guys think it would be more costly to make a 1JZ make 700rwhp or a 2JZ make 700rwhp?
Old May 4, 2005 | 12:21 PM
Bean's Avatar
Bean
CL Folding 1,000,000
it would probably cost the exact same, manifold would be slightly different tho...
most people didnt pick the 1jz over the 2jz because the 1jz can make as much power... they picked it because its WAY cheaper... less than a fifth the price actually...
there really isnt a "MOST" of what you can get out of a motor... hell, 4 years ago, 900whp was insane... well Marko dynoed 1520whp through an automatic not too long ago and there's a multitude of Supras making over 1000whp... just hasnt been many people to use the 1jz over here yet...
the 1jz with its oversquare design should be able to match the 2jz or at least come close to it; because it has more potential to rev safely into the higher-end of the powerband... part of the reason the little RB26 can pump out ridiculous numbers too... short stroke motors rev like crazy
Old May 4, 2005 | 02:09 PM
ki_soarer's Avatar
ki_soarer
i believe the numbers your searching for are 919WHP, and 1340!!!!!
Old May 4, 2005 | 02:10 PM
ki_soarer's Avatar
ki_soarer
oh, the 1340WHP is on a stock bottom end....... this is what i was told, so done jump down my throat! i have a reliable source... the car is in japan from what he said.
Old May 4, 2005 | 02:32 PM
got_trd's Avatar
got_trd
A 1jz can do just about anything a 2jz can do. Everyone just builds the 2jz-gte because they are already here in the states and come factory on the MKIV's.
Both engines are basically identical so there for building one or the other would be about the same. Its just the fact that there arent many 1jz's in the states so not to many people have put them to their limits..... (yet)
Old May 4, 2005 | 07:51 PM
mteele's Avatar
mteele
CL Folding 10,000
Yah, yet......from the way the 1JZ swap has exploded on these boards, we should start to see a lot more soon.
Old Jan 12, 2006 | 09:17 AM
pass1914's Avatar
pass1914
Default Here's some....
This is my old car, 1jz w/PT61 turbo !
Old Jan 12, 2006 | 09:24 AM
pass1914's Avatar
pass1914
Default Here is a close friends....
Top end monster, completely stock motor w/single turbo and cams
Old Jan 12, 2006 | 10:49 AM
soarer479's Avatar
soarer479
there is no doubt in many ppls mind that the 1j is very capable of making great power but there is still no replacement for displacement. the 2j will probably just make power slightly easier than the 1j having a half a liter on it. but by no way is it hard to make power on a 1j.
Old Jan 12, 2006 | 01:19 PM
ATL-SC's Avatar
ATL-SC
does anyone have a link to pics, or dyno charts, or threads on the 900hp 1jz in GA
Old Jan 12, 2006 | 02:27 PM
Arizona's Avatar
Arizona
Yep 1340whp on a stock bottom end. From MY source, I believe car also revved 9k rpm.
Old Jan 12, 2006 | 10:09 PM
LeXuSrAcIn's Avatar
LeXuSrAcIn
Wow 830rwhp isnt shabby at all!!
Old Jan 13, 2006 | 05:24 AM
aswang's Avatar
aswang
good lord! Hope to be there some time soon. How much psi were you running here?
