installing front sway bars
Old Mar 8, 2005 | 04:59 AM
chitwnsazn's Avatar
chitwnsazn
Default installing front sway bars
just got the rear daizen sway bar installed and it took a little longer then expected trying to get the old one out and new one in withought removing the exhaust piping. Now I haven't looked at the fron yet but is the front going to give me more trouble? Am I going to have to remove some of the exhaust piping to get it out?
Thanks
Old Mar 8, 2005 | 12:51 PM
rscott's Avatar
rscott
the front isnt hard at all. The hardest part will be finding all the little bolts to move the plastic pieces out of the way. Also, use some wd40 on the endlink nut. If it seems like youre note going anywhere with a rachet, you might need an allen key in the bolt part to lock it while you use a box wrench to get it off. Shouldnt take long at all.
Old Mar 8, 2005 | 12:57 PM
chitwnsazn's Avatar
chitwnsazn
haha yeah i tried using the allen wrench on the rears but there was so much dirt and crap that it kept slipping. Ended up using pliers to hold it. Thanks for the reply
Old Mar 8, 2005 | 02:25 PM
speedking's Avatar
speedking
Thanks
Where did you get your sway bars at?
Old Mar 8, 2005 | 02:53 PM
chitwnsazn's Avatar
chitwnsazn
bought it used from a club lexus member
Old Mar 8, 2005 | 02:57 PM
speedking's Avatar
speedking
I've been looking at buying these....but OUCH....$500:
http://www.tmengineering.net/suspens...n/make/sc.html
Old Mar 9, 2005 | 06:07 AM
MongolKhan's Avatar
MongolKhan
I have ordered mine, Do-Luck sways, $800. So this thread will be very helpful to me pretty soon.
Old Mar 9, 2005 | 09:03 AM
RobSoVIP's Avatar
RobSoVIP
I just had to lay under the fronts for a little while and get a good grasp on it all, then just unscrewed the plastic pieces, and endlinks... fairly simple after that, although some "wiggling" was necessary to get the old out and the new in.
I had to take my exhasut off the two rear hangers, and the two hangers right in front of the rear tire, then slid the rear bar out that ways (over the exhaust piping and mufflers).
BTW- you got the Do Luck bars!?! I was always intrigued by them- are they adjustable like my daizens?
Old Mar 9, 2005 | 09:53 AM
chitwnsazn's Avatar
chitwnsazn
I got the rear out without having to remove any exhaust piping, just had to push down n the exhasut a little bit with a long pipe/bar. The front didn't need any exhaust removal right
Old Mar 9, 2005 | 09:57 AM
chitwnsazn's Avatar
chitwnsazn
SC400TEXAS, how do you like your setup with the tokico blues, espelirs, and the daizen sways?? I have everything you do except the tokico blues. Don't know if I should get full coilover, which would not enable me to get the turbo, or just get the tokico blues and go turbo. I've been building up my suspension to prepare for the turbo for the past year and would like to know if that setup would support the turbo. Thanks
Old Mar 9, 2005 | 10:17 AM
rscott's Avatar
rscott
stay stock =)
the squat will be great for your launches.
Old Mar 11, 2005 | 06:50 AM
RobSoVIP's Avatar
RobSoVIP
Originally Posted by rscott
stay stock =)
he is right, if your going to straight line speed, stay stock. If not, then I would just recomend doing your turbo, then upgrading to Coilovers as soon as possible. No use wasting money on tokico's when your are looking to go the coilover route soon.
NikonGuy
Apr 21, 2016 07:43 PM
GILLEXUS
Suspension and Brakes
17
Oct 3, 2006 09:52 AM
antigeek
Jul 12, 2006 08:20 AM
fnutz
Jan 29, 2006 12:44 AM
TexasGS
33
Nov 1, 2005 03:49 PM
