Daizen bushing install
Old Dec 29, 2004 | 05:32 PM
djl's Avatar
djl
Default Daizen bushing install
Hi guys,
Need help with Daizen bushing installation. I know some of you were able to air hammer out the old bushing and sleeve out of front lower control arms, how did you do it exactly? Please give me details as to what type of tip you used and the exact hammer location. Thanks in adavnce.
DJL
Old Dec 31, 2004 | 05:21 PM
siaxazn's Avatar
siaxazn
i heard ur supposed to burn it out
Old Jan 1, 2005 | 08:40 AM
djl's Avatar
djl
Yes, but now I'm having difficulties getting the sleeves out.
Old Jan 1, 2005 | 01:53 PM
SCV8's Avatar
SCV8
I think you'd better read the instructions if you have them; from what I recall those poly bushings require the use of your existing sleeves.
I think that's a pretty strange way to make a set of bushings, when I took mine apart to replace them, I noticed that the sleeves themselves weren't really centered all that well within the control arm bores, weren't even round.
Why not just make the bushings to replace the entire assembly?
Oh well, ranting over now, good luck, use grease.
Old Jan 2, 2005 | 10:04 AM
djl's Avatar
djl
I bought the kit complete with new outer and inner sleeves, but can't get the old sleeves out. Going to try to contact local machine shops to see if they can get it out for me.
Old Jan 2, 2005 | 11:02 AM
PERRYinLA's Avatar
PERRYinLA
Yeah machine ships have those nice hydraulic bench presses to push out the sleeves. It is not as easy, but you may be able to get the same affect with some c-clamps (try a propane torch at the same time to loosen the bond to make it easier to remove). Some auto parts stores will loan you a "2 jaw" tool:
Or, since you have new sleeves ready to go and don't need the old, maybe you can hacksaw them out, like CL member Earl! did:
http://www.lexls.com/rcabushings.html
By the way, Earl! has one informative site for LS and SC DIYers- check it out at: http://www.lexls.com/tutorials.html
Old Jan 2, 2005 | 03:40 PM
djl's Avatar
djl
Thanks for the links Perry, very informative.
Old Jan 3, 2005 | 03:19 PM
SCV8's Avatar
SCV8
That's better than I'd first thought, it also would be nice to have the new parts installed with a press, and some fixturing instead of a just bench vice.
Old Jan 3, 2005 | 03:59 PM
mikeloc24's Avatar
mikeloc24
I know a machine shop near me said they'd charge me $5 each to press out the old ones and press in the new ones...that's IF I walk in with the control arms in hand and all they have to do is the press work. For that price I'll pay someone else to do it...maybe you should call around and see what machine shops in your area would charge if you're not up to doing it yourself.
Kyle Harty
Feb 8, 2012 11:21 AM
aarondds
Suspension and Brakes
Oct 6, 2010 03:47 AM
bwilder10h
Aug 7, 2007 01:34 PM
Panerai127
20
Oct 26, 2006 07:30 AM
VehicularL
Nov 16, 2004 09:12 PM
