Control arms
Old Oct 21, 2004 | 05:42 PM
sc400guy's Avatar
sc400guy
Default Control arms
Hello, i own a 93 sc400 with 109,000 miles on it. my question is when i drive in the city it grabs really bad on say a crack or bump, it swerves harsh, just takes the wheel. Is this my lower control arm bushing worn out? I know new ones are $395.00 each side anything else out there to fix it if that is indeed it. Thanks
Old Oct 21, 2004 | 07:57 PM
One HoT's Avatar
One HoT
CL Folding 10,000
What does that exactly mean?
Old Oct 21, 2004 | 08:57 PM
mrshabo's Avatar
mrshabo
I thought daizen bushings were around 250. It could be your shocks that are blown out. Do you mean they are making a popping noise when you go over bumps?
Old Oct 21, 2004 | 10:43 PM
bean_8044's Avatar
bean_8044
Its called tram-lining. Something like that at least... You can get the Daizen's which are a good performance upgrade, but you have to grease them every few months and you wont have the stock ride. I think you can get the Vlamos(vftbushes.com) bushings for 4-500 and you get front upper and lower. Only problem is that he's in Australia which makes shipping slower, but they are supposed to be the closest to stock you can get.
Old Oct 22, 2004 | 06:25 AM
RTLEXSC's Avatar
RTLEXSC
Or you can get the supra control arms for the front for $200.00 each.
Old Oct 22, 2004 | 11:45 PM
DoubleWhoosh's Avatar
DoubleWhoosh
You really don't have to grease them every few months. They normally go 40-50,000+ miles without needing servicing, maybe more.
Why don't they ride like stock? We have installed over 100 sets and people can't tell the difference from a new arm.
Where do you people get this (mis)information from anyways???
Old Oct 23, 2004 | 01:09 AM
bean_8044's Avatar
bean_8044
I got it from someone else who installed them. He said there was an annoying squeak that he couldnt live with and he had to re-grease them after a while. Guess he wasnt doing it properly.
Old Oct 30, 2004 | 08:35 PM
DA51's Avatar
DA51
Default front lower control arm bushings
Someone a while back did the install of newer front/lower control arm bushings in a 92 or 93. The fit was perfect.
Toyota part numbers front bush-48654-24040, need two; and back bush-48655-24050, need two.
All four bushings are around $160.
If the Stopper washer is missing in the front bushing area, part number is 48657-24020.
If your lower ball joint is worn, then a new control arm is needed.
Also, check the rubber bushings holding the steering rack for wear.
Old Oct 30, 2004 | 11:18 PM
DoubleWhoosh
Yes, improper installation once again. Sure amazing when hundreds can have no problems with something, and then all of a sudden a product is so bad because you "heard" about some "problem".
You are doing a great disservice to this site when posting that type of second hand information, especially when you have no actual conclusion.
Old Oct 31, 2004 | 12:18 AM
G Star's Avatar
G Star
Default Re: Control arms
Thats happened to me before, going 40mph, hit a pothole then the car jerked to the right almost running off into a ditch. very scary, I almost had a heart attack.....
tedsterb
Suspension and Brakes
Feb 2, 2016 10:31 PM
4ntvings
Oct 13, 2011 01:58 PM
handzilla
Dec 31, 2008 09:31 AM
CTgs300
GS - 1st Gen (1993-1997)
Jun 15, 2005 05:12 PM
David Davis
May 21, 2001 04:35 AM
