power steering leakage...common problem
Old Aug 24, 2004 | 02:48 PM
indypwr's Avatar
indypwr
Default power steering leakage...common problem
there is a leakage coming from the bottom of the power steering reservoir....
any ideas what i need to replace?
tks fr ry help
Old Aug 24, 2004 | 06:12 PM
ki_soarer's Avatar
ki_soarer
have you tried simply trying to tighten the connections on the bottom?
Old Aug 25, 2004 | 09:30 AM
indypwr's Avatar
indypwr
Post
no, not really...i just did a visual check and i saw some leakage...
Old Aug 26, 2004 | 01:03 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
indy,
It's a common problem on V8 Soarers/SC400's, but make it a priority to get it rebuilt, ASAP as the fluid will eventually kill your alternator (as what happened with my friend's Soarer V8), check your PS pump as well.
Wait... I know the pump is a common problem, maybe the resevoir is as well?
Old Aug 26, 2004 | 07:56 AM
johnee78's Avatar
johnee78
Originally posted by Soarer_25GTT
indy,
Indy has an sc300..Inypwr, I replaced my powersteering pump last year it's one of those things that just goes...I went with a new factory one and I'm very pleased with the steering..I don't know how much it is because I got a good price but I always like to go with the factory replacement as long as it's within reason...
Old Aug 26, 2004 | 11:20 AM
indypwr's Avatar
indypwr
Post
tks for the advice........guys!
my mechanic told me that one of the o-rings in the bottom of reservoir needs replacement.
i suppose it's been leaking a lot cuz i always hv to refill it at least twice a week.....
Old Oct 6, 2004 | 08:27 AM
96sc3's Avatar
96sc3
i searched in help of PS problems... since its colder out here nowadays when i turn the steering wheel at idle it groans a bit... i checked the resovoir and its not leaking... i dont see any leaks... what oculd be the problem??/ should i bleed air?
thanks
Old Oct 6, 2004 | 12:46 PM
mikeloc24's Avatar
mikeloc24
thanks
It's been discussed a trillion times and I can't reember all the possiblities right off the bat. What did you enter in the search field? Maybe if you spell out "power steering pump" or put in "pump leak" you will get more results. But I remember reading about a $1 fix and about full replacement (somewhat costly)...and every damn thing in between. If your problem is just groaning perhaps it will go away if you top off the PS reservoir. Have you tried that? I usually try to simple, cheap fixes first before I start looking into replacing pricey dealer parts. Good luck dude.
Old Oct 6, 2004 | 08:14 PM
96sc3's Avatar
96sc3
oh, thanks.... i did search.,., just didnt come up with the info that i wanted.... well.. i read the dipstick and it had fluid at the very bottom of the stick when cold.. so i added and i guess i'll see what happens after a few drives... thanks ....
Old Oct 7, 2004 | 03:04 PM
mikeloc24's Avatar
mikeloc24
I know mine groans a little too, I just add fluid and it stops. I know I have a leak in my PS pump somewhere. I'm assuming it's that damn o-ring at the bottom of the reservoir.
Old Oct 8, 2004 | 02:31 PM
indypwr's Avatar
indypwr
Post
mine too, i think that o-ring needs replacing.......
Old Feb 14, 2011 | 11:08 AM
dkekim01's Avatar
dkekim01
if its groaning you probably are low on fluid. you should also check your rack
and pinion. i had to change my pump and rack and pinion out at around 130k.
as for the bad tires. you should also check out the bushings in the lower and upper control arms. if there play w the bushings you will get uneven tire wear. simple fix is you can search the forum for TM engineering. and order the daizen bushing kit for a 150$ that replaces all the upper and lower bushings in the front end. this is much cheaper than to do the whole control arm, that lexus sells 600 a set. all youll need is a mecanic with a bushing press.
Old Feb 14, 2011 | 11:44 AM
good2go's Avatar
good2go
. . . OHHH, sooooooo close! Just off by a mere seven years
Old Feb 14, 2011 | 12:52 PM
stockhatch's Avatar
stockhatch
LOL! Sometimes I am in search mode and forget how old some of the stuff I am reading is. I have caught myself typing a reply to an ancient thread on more than one occasion.
Don't feel bad dkekim01. We bash for not searching, and then when peeps do search and get mixed up, we bash for that too! hehehe It is fun though.
Old Feb 15, 2011 | 05:32 PM
VanillaSC's Avatar
VanillaSC
Jegs also offers bushings for front control arms at a great price...
tjbantum
May 12, 2018 10:56 PM
xxjad22xx
Apr 22, 2004 01:16 PM
HD-GS4
May 2, 2003 11:19 PM
ChrisSC300
Feb 4, 2003 06:06 PM
bobc
Sep 17, 2001 05:04 PM
