SC300 Engine Light Doesn't Come On
Old Aug 4, 2004 | 11:13 AM
danieljava's Avatar
danieljava
Default SC300 Engine Light Doesn't Come On
My SC300 didn't pass smog check because the engine light didn't come on for a few seconds when the ignition key was turned. I have checked the bulb and it seems to be OK. Even replaced it with another one. Does anyone know if there is a fuse for the engine light? How can I troubleshoot the wiring? Which wire(s) going to the instrument panel is for the engine light?
Thanks.
Old Aug 5, 2004 | 05:27 AM
VSsc400's Avatar
VSsc400
i've never heard this before.... failing emissions because the cluster light didnt' come on?
I'm no electronic guru... but there are a few here that are really good... anyone chime in?
Old Aug 5, 2004 | 07:11 AM
SupraCoup3's Avatar
SupraCoup3
with the car off, turn the key to the on postion (don't start it) does the check engine light not come on?
Old Aug 5, 2004 | 07:57 AM
danieljava's Avatar
danieljava
No, the light didn't come on when I turned the key to the on position. The problem was a loose ribbon cable in instrument panel's circuit board.
Thanks.
Vinaya
Jan 15, 2024 07:59 PM
SC400slide
Jul 3, 2012 10:37 AM
k954triniz
IS - 1st Gen (2001-2005)
Jan 11, 2012 04:14 PM
airahcaz
Maintenance
Jan 1, 2009 05:18 PM
palmerwmd
Maintenance
Oct 31, 2002 10:28 AM
