No start issue unresolved!
Old Jul 8, 2025 | 11:22 AM
Ldepaso's Avatar
Ldepaso
Default No start issue unresolved!
Hi, I’m looking for some guidance on diagnosing a starting issue with my 1992 Lexus SC400.
I’ve been experiencing an intermittent no-start issue—some days the car starts up with no problem, and other days it just cranks but won’t start. Initially, I suspected a fuel pump issue, so I did a fuel pump bypass. However, the problem persisted. I can hear the fuel pump priming, so I know it’s functioning properly.
I also noticed that the car only starts when the Check Engine Light (CEL) illuminates during ignition. If the CEL doesn’t come on, the car won’t start. After trying various things, I decided to send the ECU to SIA Electronics for testing and repair. They found a few leaking capacitors and repaired them. Four weeks later, they sent the ECU back and claimed it tested fine.
However, after reinstalling the ECU, the car still won’t start—it just cranks. This time, I haven’t even had one successful start since installing the repaired ECU.
Can someone help guide me on how to properly diagnose this issue?
1992 Lexus sc400
135k miles
Old Jul 8, 2025 | 03:49 PM
Arsenii's Avatar
Arsenii
Hello,
Did the shop do anything other than simply replace the Capacitors? Electrolyte from the Capacitors, depending on the severity of the damage to said Capacitor, can also affect the PCB Traces and Neighboring Components, sometimes literally dissolving them, among other things. If the shop just replaced the capacitors and ran basic tests, chances are the ECU you got back is just as fried as it was, but now with some fresh Capacitors.
I would suggest contacting the shop for additional tests, if they claim it's working fine and the job was done right, they won't have any issues refunding you the repair costs if you send the ECU out to another company for a second opinion and they find that it's bad. While I haven't used any of their services, people around here claim that Tanin Auto is a good place for repairs like that.
Hope this helps and best of luck!
Old Jul 9, 2025 | 04:27 AM
TaninAuto's Avatar
TaninAuto
Sponsor
If the Check engine light doesn't come on, the ECU is bad. They didn't repair the correct thing and obviously didn't plug it into a car to make sure it works. We do both.
Our specific service for a no-start SC400 is here. Use the drop down menu to select your car and problem: https://taninautoelectronix.com/prod...00-ecu-repair/
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
https://taninjdm.com/
Our Lexus LS430 Dealership
lexdud
Mar 27, 2012 05:40 PM
jarrard
Jul 11, 2011 11:33 AM
sc400w58
Apr 29, 2011 06:31 PM
twizted
Apr 29, 2009 05:21 PM
rsp169
Jan 12, 2009 08:08 PM
