92 sc400 will not start
Old Apr 24, 2011 | 11:47 AM
sc400w58's Avatar
sc400w58
Default 92 sc400 will not start
hello, i have a 92 sc400, and it start acting like it wasnt firing then when i was on the road it just started acting like it was in nutral. then just died, now it will crank but it wont start.
I have a
new battery
new plugs
new wires
new cap and rotors
new igniters
new ignition coils
cleaned the crank position sensor ( it was fine)
starter is working
fuel pump is working
even bypassed fuel pump (still didnt start)
could it be my ecu? or no compression?
was wondering if theres anything else to try?
Old Apr 26, 2011 | 10:40 PM
1uzboost's Avatar
1uzboost
Check your compression and coilpack mine popped off once and ran on 4 cylinders then wouldn't start
Old Apr 29, 2011 | 03:40 PM
MUCH2PHAAT's Avatar
MUCH2PHAAT
Default Heartbroken
My car just died. Broke my heart. The mechanic says that my car needs a brain. $1200. Is he crazy? I need a second opinion or a for sale sign. I am torn just before the summer. Any techies out there that can shed some light on my 16 year old.
I have a
new battery
new plugs
new wires
new cap and rotors
new igniters
new ignition coils
starter is working
Old Apr 29, 2011 | 05:50 PM
FatBrian81's Avatar
FatBrian81
MUCH2PHAAT: There have been a few people here who have replaced all of the capacitors on their ecu, it runs between $100 and $350 depending on where you get it done. Much better than $1200, you can also try a used ecu but it could have the same problem.
sc400w58: With the fuel pump ecu jumped do you have fuel pressure ? Its possible the fuel pump could be bad.
Old Apr 29, 2011 | 06:31 PM
MUCH2PHAAT's Avatar
MUCH2PHAAT
Default Plug and Play
Is ecu a plug and play part? I have searched ebay and found them to be affordable and some with warranty. I just might take my chance and replace if mechanic can assure fuel pump ecu is not bad.
Is reprograming necessary? Fuel pump was replaced in Nov. 2010.
Aniyah87
Jul 16, 2018 01:59 PM
mlee934
Maintenance
Jul 12, 2017 01:56 PM
defrag010
Jan 18, 2009 08:03 PM
