How do you activate the Traffic Jam Control?
speed on my new RX350h.
1. How do you activate the Traffic Jam Assist?
2. From videos, it appeared that all highly optioned RX’s came with the power rear seat recline. Yet I don’t seem to have it on my $65,755 RX. Am i
missing something? EDIT: I now know I don’t have this.
3. It appears that the problem getting the Digital Key to work has existed for a very long time on the NX before becoming an issue here. Any update on what and when the resolution will be?
4. Is there any way to get tire pressure to be an option that can be seen on the driver’s mini screen or HUD?
5. I’m finding no brake dust from the hybrid brake pads. Wonderful. So why aren’t ALL brake pads made from the same stuff? (Sorta like why isn’t the whole plane made from the indestructible black box material 🤣?)
6. What exactly happens with setting current and indicated tire pressures, as per this photo? Does something beep when low? Does the vehicle add pressure automatically (doubtful)? It shows the current pressure…so why does it need to be “set”?
2. Also like a $200 option.
Check your window sticker to see if either of these are listed.
2. I guess I do not have this. Hard to believe on a $66k car, but no one goes back there anyway. 🤷🏻♂️
https://www.youtube.com/watch?v=qEXjipYjLYw
Also the driver of that car has his hands off the wheel for an extended period of time. If I do that, it flashes all sorts of warnings.
Yes, it forces you to touch the wheel periodically because its not an autonomous driving system, just an assistant. I've only used the BMW system, I always kept my hands on the wheel on that one so I never dealt with the alert, just used the traffic assistant to handle the throttle and braking as traffic ebs and flows (including dead stops). On the BMW at least, the lane keep assistant (I think Toyota calls it Lane Tracing) didn't work so well, it oscillated from one white line to the other, so I turned it off and steered myself. There was nothing to activate on that system, it was engaged when the cruise control was activated.
Yes, it forces you to touch the wheel periodically because its not an autonomous driving system, just an assistant. I've only used the BMW system, I always kept my hands on the wheel on that one so I never dealt with the alert, just used the traffic assistant to handle the throttle and braking as traffic ebs and flows (including dead stops). On the BMW at least, the lane keep assistant (I think Toyota calls it Lane Tracing) didn't work so well, it oscillated from one white line to the other, so I turned it off and steered myself. There was nothing to activate on that system, it was engaged when the cruise control was activated.[/QUOTE
Ah! I was thinking ACC as in the “Accessory” function of traditional cars.
In the Toyota Highlander video, the driver almost never touches the steering wheel. The Lexus will flash and beep if I try that.
Actually, looking at the manual now, it seems to have a mind of its own based on other actions it detects - to push this alert to grab the wheel. Its not just a timer.
Page 552 of the manual - you can turn this entire function on or off, I would think the default would be ON - but you never know. It also has camera recording of the driver during the operating period, that also can be turned on or off.
It will be great if anyone else can confirm my observation. My dealership's "Lexus feature guy" did not walk me through all the features. So, I am figuring out features on daily basis through owner manual and trial/error.
You don't need lane keeping to be on to use the BMW system, I know that for a fact. If you need it on for the Lexus system, hopefully their Lane Tracking system works better than BMW's.
