Latch broken on center concole cover
Old Mar 1, 2026 | 08:06 AM
Urlik's Avatar
Urlik
Default Latch broken on center concole cover
Just ran into an issue with our center console lid that we'll have to get warrantied. When you depress the release on the driver's side and lift the cover, you hear a click of the latch resetting right away. This isn't supposed to happen until you close the lid. When it clicks, you then need to depress the button again to close the lid.
Old Mar 2, 2026 | 04:25 AM
SymbioticSix's Avatar
SymbioticSix
I had an issue where mine would pop open at random. Lexus replaced it without questions.
Old Mar 2, 2026 | 04:37 PM
madmax24's Avatar
madmax24
I have found mine open several times and thought I just forgot to close it. This explains it all.
Old Mar 3, 2026 | 07:54 AM
N4TECguy's Avatar
N4TECguy
Mine was replaced before I owned it. Seems to be a common issue. Wish I knew how intensive it was to replace this
Old Mar 8, 2026 | 01:47 PM
DodgerFan's Avatar
DodgerFan
4th Gear
I just had mine replaced under warranty on my 2023 RX 350h. It took the dealer about 90 minutes, including getting the car washed. The part had to be ordered and took about a week to arrive. The service advisor indicated this is a common problem that most people are not even aware it is an issue. I probably had the defect since I purchased the car new and only recently discovered I had to push the button on the driver's side to close the console while on passenger side the console closed by just pushing the lid down.
Old Mar 10, 2026 | 05:46 PM
Yobuda's Avatar
Yobuda
Same issue here. Dealer denied warranty stating that I broke the lever that keeps the latch open while slamming the lid - definitely didn't do that.
If you open it up you will see a little lever on both driver and passenger sides - the side that works will be evident while the side that doesn't may be inside it's "closed" slot.
I took the lid off of the console assembly (can pull it up around the edges, it's just clipped in) to investigate what was broken.
Turns out the lever has a spring on it and the lever has two posts that fit into holes so that it can pivot. The pivot supports have become weak, allowing the lever to fall out when under pressure.
My solution was to brace the pivot supports between the driver and passenger sides with a wedge so that the lever would not fall out of the pivot supports.
May need to follow up with photos....LOL.
Old Mar 10, 2026 | 06:16 PM
Urlik's Avatar
Urlik
Yeah, some photos may help follow.
Old Mar 10, 2026 | 07:10 PM
Yobuda's Avatar
Yobuda
If you pull the lid off, this is what you see.
I also tried to attach a video showing how it works.
I will likely replace the wood with something adjustable - mini-all thread with nuts maybe.
Lid pulled off, showing left and right levers.  Temporary wood between the pivot posts keep the drivers side from flexing and allowing the lever to slip out.
File Type: mov
Old Mar 10, 2026 | 07:19 PM
Urlik's Avatar
Urlik
Interesting. As I said, mine hold for a second or two then the latch assembly slams into the lock position that is supposed to happen when you close it.
Old Mar 10, 2026 | 07:25 PM
Yobuda's Avatar
Yobuda
Same thing for me.
Pull the leather lid off and see what is happening.
Old Mar 10, 2026 | 07:33 PM
Urlik's Avatar
Urlik
Originally Posted by Yobuda
Same thing for me.
Why would I do that when I still have a warranty? Figuring out how to jury rig fixes for a possible poor design will come after the warranty ends.
drich2905
LX - 3rd Gen (2008-2021)
Apr 12, 2025 06:36 PM
sajack
LS - 5th Gen (2018-present)
Nov 13, 2022 11:27 AM
lex442
Jul 18, 2020 09:20 AM
shortduck
RX - 3rd Gen (2010-2015)
Mar 9, 2019 04:44 AM
GXlexus470
GX - 1st Gen (2003-2009)
Dec 29, 2007 07:43 AM
