TSB fo System malfunction
Old Aug 5, 2025 | 05:52 AM
js6543md's Avatar
js6543md
Default TSB fo System malfunction
Saw on Facebook Lexus group that there is a TSB for System Malfunction that shows on Start-up. Also, that Lexus is working on Amplifier
replacement for crappy ML Audio system
Old Aug 8, 2025 | 11:44 AM
genmaster's Avatar
genmaster
if Lexus is working on replacing the amp, is this for all vehicles? and does it mean some cars have this issue and some dont? From reading all of the comments regarding the ML audio everywhere it sure feels like everyone is having the exact same problem. Personally I can hardly hear my bass but if I turn over vol to 30+, then it comes alive.
Old Aug 9, 2025 | 07:52 PM
BLUKTY2's Avatar
BLUKTY2
Are you referring to the SHIFT System Malfunction message or a different one? Also curious about the amp replacement, as I have been very disappointed in the ML sound system since I took delivery of the vehicle. Thanks for the information!
Disregard my question on the System Malfunction; I just saw your previous post.
Old Aug 18, 2025 | 10:45 AM
CAPTBob's Avatar
CAPTBob
Took my wife's 23 RX 350 (ICE) in for service today. I asked about the TSB for the "Shift SystemMalfunction". The Service Advisor was very aware of the issue and added it to the scheduled maintenance. On the service receipt reprogramming the ECM as per the TSB was listed as taking 0.7 hours of work. Will have to see when it gets cold if the problem is solved.
Old Aug 18, 2025 | 11:15 AM
KennyJohnson's Avatar
KennyJohnson
Did your wife's RX have any warning at start-up? If not, it was quite interesting that the dealer "added it to the scheduled maintenance" by "reprogramming the ECM." Why tried to fix an issue while none existed to begin with?
Old Aug 18, 2025 | 11:58 AM
CAPTBob's Avatar
CAPTBob
Periodically last Winter my wife's RX did have the "Shift Malfunction" error pop up. Now, in the Summer, she hasn't had it reoccur. Hopefully the completion of the TSB will preclude the fault from reappearing when the cold weather returns.
Old Aug 18, 2025 | 12:13 PM
nb082481's Avatar
nb082481
10th Gear
which model having this issues?
Old Aug 19, 2025 | 11:50 AM
KennyJohnson
Thanks for your clarification. My cars (including the RX) are always garaged when not in use, and perhaps that may explain why I have not encountered the malfunction notification since indoor temperature is generally warmer than outdoor in the winter. I also notice that you are from Michigan and the winter temps are much colder than those in New York City.
Old Aug 20, 2025 | 03:42 PM
lexusnyca's Avatar
lexusnyca
It occurs in NY too (outdoor parking). I also had the fix applied and we will see if it works this winter.
js6543md
RX - 5th Gen (2023-present)
Nov 20, 2025 01:01 PM
sp73
GX - 1st Gen (2003-2009)
Jan 23, 2023 01:30 PM
MustangSal
Automotive Care & Detailing
Oct 30, 2016 04:51 PM
edwinlexus
May 31, 2015 06:48 AM
thwang99
May 3, 2004 08:24 AM
