Engine Braking - with PDA on
Old Jun 21, 2023 | 09:19 AM
Lexus-SSA's Avatar
Lexus-SSA
Lightbulb Engine Braking - with PDA on
I have had my RX350h for about a week. I have been reading the manuals and testing all available systems, functions, safety sense 3.0, etc.
When I turned on the PDA safety option last night, I noticed that on a down grade slope, while I did not have my foot on neither of the pedals it did some engine braking instead of using the brake system even though the car in front of me was probably 500 feet ahead of me. The engine braking pushed the rev up to 3000 RPM. I was expecting some use of the brake so it can go into battery regeneration ! Any of you have had any similar experience?
Old Jun 21, 2023 | 09:39 AM
Urlik's Avatar
Urlik
I’m assuming you know that the brakes weren’t used because it didn’t light up the braking symbols on the dash?
Old Jun 21, 2023 | 09:48 AM
Lexus-SSA's Avatar
Lexus-SSA
I really did not pay attention to the brake lights on the dash. I will test it again, but I did notice the engine braking because as you know the 350h engine is LOUD.
Old Jun 23, 2023 | 03:43 PM
lexusnyca's Avatar
lexusnyca
I turned those brake indication lights off, I can't see them anyway at the bottom of the dash display.
Old Jun 23, 2023 | 04:41 PM
Urlik's Avatar
Urlik
Honestly I find the 9” gauge cluster to be a p.o.s.. Small and poorly positioned. Only makes me wish the HUD showed even more info.
Old Jun 24, 2023 | 01:55 AM
ggebhardt's Avatar
ggebhardt
Why can’t you see them?
If you are not sitting high enough to see the bottom of your instrument panel, it could be causing the "sit up" message.
Just saying . . .
I am only 5-11 and see the brake lights on the instrument panel with much room to spare.
Old Jun 24, 2023 | 08:15 AM
lexusnyca's Avatar
lexusnyca
I think I can't see them because I have the steering wheel height very high, and that obscures the bottom of the instrument panel where these tail light indicators appear. So I turned them off.
Old Jun 24, 2023 | 08:43 AM
ggebhardt's Avatar
ggebhardt
‘Could it be that you having the steering wheel very high that it is pointing the attention sensor higher and causing the “sit up” message? The sensor is mounted on the steering column.
Old Jun 24, 2023 | 01:28 PM
lexusnyca's Avatar
lexusnyca
Yes, the sensor could indeed be shooting over the top of my head given the height of the wheel, so it thinks I am ducking down. I will try to lower the wheel a little bit to see if I like that setup.
xclream
13
Apr 17, 2015 09:55 AM
Sefo
Apr 10, 2015 04:18 AM
niteflite
Oct 13, 2010 03:53 AM
Fizzboy7
Apr 22, 2008 06:18 AM
inecstaz
Jul 29, 2006 02:01 PM
