Clunk on full lock
Clunk on full lock
My 4RX F-Sport clunks repeatedly when reversing on full lock at very low speeds.
It only does it when raining, almost like the front wheels are slipping and its not always repeatable
Does anyone else have this?
Suspension itself feels tight and can't see anything wrong.
Like I said, only happens in the wet at very low speeds when reversing. Hence why I think it may be the front wheels slipping and jumping along. Only have 15k miles on as well
its due 20k service at end of January so will see what they think it is.
is the ground you are driving on make a difference?? i noticed this going forward in my work parking garage.. they recently re-expoxied the floors... and it feels like the wheels are slipping/skipping/skidding when i turn. even at LOW speeds... we are talking less than 5mph.
I am guessing that it's the AWD system. If you have the wheel turned full lock and reverse the car the outer wheel has some catching up to the inside wheel. With the wet ground the wheel could easily slip, especially with full lock....assuming you mean the steering wheel is fully turned one direction. I would not think this is a problem.
You should get them to check the alignment while it's in for 20K. I forget which setting can make this condition worse, could be caster but not sure......again nothing to worry about.
For me, it's only at very low speeds so less than 5mph when reversing out of my drive which is tarmac. Seems to occur more when wet or cold
Yes it's only when the wheel is turned fully to one direction, doesn't do it if not fully turned but it's annoying because it means I have to do more manoeuvres to pull out of tight spaces.
To be fair I have noticed some slight tyre scrub on front left tyre outer shoulder and the tyres are low so will need changing soon
sdwtchlvr
12-11-18 03:40 PM
Gohanburne
Suspension and Brakes
12-29-16 01:38 PM
