Wheel Molding Mishap - Replace or Glue?
Old Jan 30, 2023 | 03:57 PM
sderman's Avatar
sderman
Default Wheel Molding Mishap - Replace or Glue?
My 2017 RX350 had a small mishap and one end of the black plastic molding around the rear wheel came undone (see 2 pics). It looks like the clip remained inserted in the body, but the plastic side of the clip broke off from the plastic molding.
Not sure what is the cost of a new replacement molding but I also think a new strip might not look good next to the existing adjacent molding which has now 6 years of weathering.
I was thinking that I could put super glue or epoxy on the 2 broken plastic edges of the clip and then press the molding back onto them and hold in place temporarily with tape. Or even better, a small ball of epoxy putty so only the plastic on the clip and the molding are contacted.
I would appreciate everyone's thoughts.
Old Jan 30, 2023 | 04:00 PM
That won't snap back into place? Pull that clip out of the body and snap it back into the molding. If that's a no go, clean everything up then use 3M emblem tape. Tip: heat the area up with a blow dryer or heat gun before pressing the pieces together.
Amazon Amazon
Glue will not work in that application 3M tape will.
Old Jan 30, 2023 | 04:15 PM
jrobe's Avatar
jrobe
Not sure about that exact problem but I fixed a plastic molding break once by fiberglassing it which is basically using 2 part epoxy with a small piece of fiberglass cloth imbedded in the epoxy across the break. In my instance, it held up well where glue or epoxy alone wouldn’t have worked.
Old Jan 31, 2023 | 09:01 AM
sderman's Avatar
sderman
https://www.amazon.com/dp/B002JOVUO0/
Thanks, but I don't think the clip, which is still attached to the body, can snap back onto the molding. I have circled in the picture the 2 rough edges of the plastic side of the clip which I think were torn off of the molding. Can someone who has removed this molding confirm that the molding has the clip permanently bonded to the molding?
Old Jan 31, 2023 | 10:30 AM
mikemu30's Avatar
mikemu30
Can you remove and replace the clip then?
Old Jan 31, 2023 | 11:20 AM
sderman's Avatar
sderman
I believe (but waiting for confirmation from someone who has replaced the entire molding) that the clip comes permanently attached to the molding. So what occurred here is the clip broke off from the molding and stayed clipped into the body. So my options are 1) replace the entire molding which I am reluctant to do since a new molding may not look good next to the older adjacent weathered molding, or 2) epoxy the broken plastic part of the clip (the 2 areas where I circled) back onto the existing molding.
Old Jan 31, 2023 | 12:29 PM
F3Woody's Avatar
F3Woody
I'd take a stab at epoxy repair first. JB Weld makes some great products for that.
The insert-able portion of the clip is intact, so that's a plus. With a little patience and a steady hand, should be a simple fix. And if for some reason it doesn't take, then you go to plan B.
Old Jan 31, 2023 | 01:14 PM
sderman's Avatar
sderman
Thanks. Yup, that's the direction I'm heading.
Old Jan 31, 2023 | 01:50 PM
Barry2522's Avatar
Barry2522
As a body shop owner we have tried to repair molding like that so many times with 50/50 chance of it holding for a while .
The plastic has to be very clean [alcohol] and roughed up if possible . A new molding is 150.99 list price . Also a new molding would look
fine matched up to the rest .
Old Jan 31, 2023 | 01:55 PM
sderman's Avatar
sderman
I wonder what material the molding is made of? JB Weld's 5-minute epoxy appears to be the same as Loctite's, and the manufacturer for Loctite says the epoxy will not bond polyethylene, polypropylene or nylon. Does anyone know?
lexus13dan
Dec 12, 2022 03:52 PM
SA183
RX - 4th Gen (2016-2022)
Jun 25, 2020 07:11 AM
itsmike177
IS F (2008-2014)
Feb 29, 2020 10:52 AM
wfz
RX - 1st Gen (1999-2003)
Jul 18, 2017 09:44 AM
Henry82
20
Nov 23, 2015 01:08 PM
