2016 Engine Rattle
It's probably the direct injection cleaning cycle noise:
https://www.toyotanation.com/threads...ngine.1631730/
https://www.reddit.com/r/ToyotaTacom...and_engine_is/
https://www.toyoheadquarters.com/thr...oise-3-5l.480/
OP, With the limited information we have and without the ability to hear your noise, we're just guessing. Does the sound change with flucuating engine RPM's? Does it make the same noise when the engine is cold and hot?
Just a rattle that does not change with change in engine rpm. Some component or accessory might be loose and close to something else. It could be 100 different things. Take a long screw driver and lightly press on parts of the engine while it is idling. Please stay away from moving parts. See if you can isolate it.
Skibumz
Aug 18, 2021 08:57 PM
Mewannalex
Nov 12, 2019 02:02 PM
