Power Liftgate Problem
Old Dec 12, 2021 | 01:25 PM
RollingBlu's Avatar
RollingBlu
Default Power Liftgate Problem
HELP! I did a quick search but didn’t find anything like my problem. I have 2016 RX 450h but I’ll assume the liftgate is identical to an RX350. I disconnected the battery briefly and now the power liftgate doesn’t work. It just makes two beeps and doesn’t move either up or down. Same thing if I use the liftgate button, the FOB or the dash button. It’s open now – I don’t want to force it closed since it might get stuck like that.
As far as I can tell, every other function on the car is OK. I went into Vehicle Settings to make sure that the power was enabled, I even disabled it and enabled it again. The doors are unlocked, the Lock/unlock function is OK.
There is a fuse labeled PBD which I assume means Power Back Door but that whole row of the fuse panel has a blue bar over it. WTH is that?
Thanks, Any suggestions would be greatly appreciated.
Old Dec 12, 2021 | 02:13 PM
n0v8or's Avatar
n0v8or
Read this message thread for a possible solution.
https://www.clublexus.com/forums/nx-...nnect-fix.html
Old Dec 13, 2021 | 05:53 AM
RollingBlu's Avatar
RollingBlu
Thank you!, Thank you!, Thank you!
This was the solution. This probably saved a trip to the dealer and a big bill!
Shan2015
14
Feb 15, 2025 02:49 PM
Heids82
Nov 1, 2021 06:26 PM
GeneWAZ
RX - 1st Gen (1999-2003)
Feb 14, 2021 12:28 PM
Nehptis
Jun 16, 2013 10:06 AM
galicianer
RX - 3rd Gen (2010-2015)
Aug 6, 2012 10:41 AM
