USB Ports not working....
Old Aug 13, 2021 | 10:10 AM
Janbillc's Avatar
Janbillc
Default USB Ports not working....
I just purchased a pre-owned 2018 RX350 & I love it...my only issue is the USB ports do not charge my LG Velvet Android phone.
my 2017 Highlander had no problem charging my phone. Does anyone else have this issue?
Old Aug 13, 2021 | 06:49 PM
RXWes's Avatar
RXWes
Have you tried multiple charge cables?
Do the ports charge any other device?
Is there dirt or corrosion inside the USB ports?
Old Aug 13, 2021 | 06:53 PM
Janbillc's Avatar
Janbillc
The ports are perfectly clean...I have tried different charge wires & different phones.
Nothing works!
Old Aug 13, 2021 | 07:16 PM
Cocal's Avatar
Cocal
Have you tried the port under/inside the armerest?
Old Aug 14, 2021 | 09:24 AM
ravenuer's Avatar
ravenuer
Nothing works!
Blown fuse?
Old Aug 14, 2021 | 09:37 AM
RXWes's Avatar
RXWes
If the fuse is ok. And you checked the other things. You may have a bad harness on the center consoles
This is a video for a IS. But how you remove the trim pieces will be similar.
https://m.youtube.com/watch?v=aphZmmA2rEE
Look at the wire harness and see if it’s disconnected
https://www.ebay.com/itm/184467523940
Old Aug 14, 2021 | 11:48 AM
mcomer's Avatar
mcomer
Try using a known good cable and select "Media" and listen for tunes from your device.
The USB ports only provide 500 mAmps (0.5 Amp) current so are not a great charger.
If you are also getting no signal then you must diagnose further.
davyjordi
Jan 26, 2020 12:46 PM
ultran00b8
Mar 27, 2014 01:24 PM
GregsLexus
RX - 3rd Gen (2010-2015)
15
Feb 21, 2012 12:43 PM
qwertys
RX - 1st Gen (1999-2003)
Mar 28, 2006 02:40 PM
