Sugestions for Brake Service
We're at roughly 45K on our 17 RX and front pads are just about ready for replacement. Question - should I have the dealer service or search for a less costly independent? Anything unusual about replacing these as compared with other cars?
It doesn't matter who as long as they have the technology to do it, yes even for brakes one has to get into the @#$%# computer. Also have you changed the brake fluid yet? It should be done every 3 years according to the manual.
Yes definitely will have the fluid changed as well.
You can do it yourself but the electronic parking brake requires that you retract the rear calipers, but NOT by compressing. You can either use the computer (TIS system) or there is a way of mechanically using a torx to retract. There is also a way to jumper power to the motor in the caliper to retract but I would not use that method....could cause some other problems. Like everything, even basic maintenance is becoming more difficult/complex to do. When the time comes I will do with the torx method. Fronts are pretty standard.
The electronic parking brake makes me nervous about having my independent mechanic do the brakes.
Is the Techstream software that they have at Toyota dealerships the same as what they have at Lexus?
Could I have an independent mechanic replace the front brakes only, then take it to Lexus/Toyota to replace the electronic rear brakes?
Front brakes are normal job. Even an informed independent should have no problem doing the rear brakes if they are any good, but you could do fronts at one place and rears at a Lexus/Toyota place. The fronts generally wear much faster.
Find a good shop and let them do it.
I had all four pads replaced at 78000km. Was at a independent shop. Was told that the front pads are basically gone but the rotors are still good. If waited until maybe 85000km then the rotors have to be replaced as well. Didn't hear anything about the rear parking brakes, maybe because there are so many RX driving around in GTA, Ontario area that everyone knows how to work on them.
I was under the impression that modern cars are designed to have rotors and pads replaced together since you can have lighter rotors and have less weight under the suspension. Of course, that makes dealership happy too.
zuluzulu
RX - 3rd Gen (2010-2015)
Jun 9, 2017 04:22 AM
ghostown
Suspension and Brakes
Oct 27, 2008 12:46 PM
