Rear diff torque specs
Old Aug 26, 2019 | 01:32 PM
diyall's Avatar
diyall
Smile Rear diff torque specs
Hi,
I am planning to replace rear differential oil for my 2017 RX 350 AWD.
I searched Web for a couple of hours but all I could find was specs for other Toyota vehicles - my best guess was 29 ft-lb for drain plug and 36 ft-lb for fill plug.
Would someone please confirm above torque specs are the same for RX 350?
Thank you very much.
Old Aug 27, 2019 | 06:46 AM
chunktwo's Avatar
chunktwo
id say - use the latest info you can find for the toyota highlander. and then check it in few hundred and then a few thousand miles..
how many miles do you have on the car that you plan on changing the fluid?
any reason you arent changing the transfer case fluid too?
Old Aug 27, 2019 | 07:38 AM
diyall's Avatar
diyall
It is about 16 K. Maintenance manual states that rear differential oil needs inspection or replaced (if it is used to tow things) at 15K.
While I am inspecting it, I may just replace the oil since it is a quick job.
No plan to change transfer case oil
Old Sep 10, 2019 | 06:53 AM
diyall's Avatar
diyall
Default replaced both transfer case and rear differential fluid
I thought it was hard to reach the fill hole of the transfer case. But it actually was easy to open the fill hole. So I changed both fluids at the same time.
At 16K without towing, fluid was relatively OK. I see black gunk on magnets of both drain bolts. Transfer case fluid was in better condition. Rear differential oil was much darker.
I used redline 75W85 GL-5 Gear Oil since their web site shows compatibility.
https://www.redlineoil.com/75w85-gl-5-gear-oil
I used the same torque specs that I mentioned my initial post.
Old Sep 10, 2019 | 12:23 PM
autotech13's Avatar
autotech13
The correct gear oil to use for the Lexus RX is 75 W 90 GL 5!
Old Sep 11, 2019 | 04:41 PM
diyall's Avatar
diyall
Smile 75W-85 GL-5 is what's on the manual
autotech13, thanks for the comment.
I am not sure where you got the information. 75W-85 GL-5 is what's on the manual. I guess, both 85 and 90 seem OK, though.
Old Sep 13, 2019 | 04:10 PM
autotech13's Avatar
autotech13
Hi diyall. I got the specs. from my Amsoil Product Look up page.
Old Nov 8, 2021 | 06:39 PM
cocala's Avatar
cocala
Default Torque Specs for Rear Sway Bar and End Links
Hi,
I just replaced the stock RX350 F Sport rear sway bar with Hardrace rear sway bar which made a huge difference. However, I couldn't find the torque specs for the end links and the sway bar bracket. Does anyone have any idea? Thanks.
Old Nov 8, 2021 | 07:05 PM
RX300 has 29 for the link to bar and 14 for the bracket that holds the bushing to the body. I would use that. Pound feet scale.
Old Nov 8, 2021 | 07:08 PM
cocala's Avatar
cocala
Thumbs up
Thanks for that. What year is RX300? 29 and 14 are ft-lbs or NM?
Old Nov 8, 2021 | 08:25 PM
ft-lbs, it was from a 2002 service manual. The sway bar bracket spec especially will be the same (same size fastener), the end link that is hard to over torque.
Old Nov 8, 2021 | 08:30 PM
cocala's Avatar
cocala
I have to adjust them then, I tightened them to 65 ft-lbs and 23 ft-lbs last night. Hope the end link won't have any damage.
Old Nov 9, 2021 | 01:28 PM
Quantum501's Avatar
Quantum501
never mind....just noticed that I was replying to a 2 year old question
Emaniat
RX - 4th Gen (2016-2022)
19
Jul 24, 2018 04:39 PM
mohsen
Sep 15, 2017 07:32 AM
Leslieh
RX - 3rd Gen (2010-2015)
Mar 31, 2016 09:50 PM
tizelwazze
Apr 1, 2015 05:25 AM
MNSC3
May 16, 2014 02:15 PM
