about doing the brakes without the scan tool.
Old Oct 29, 2018 | 08:42 AM
bobgailw's Avatar
bobgailw
Default about doing the brakes without the scan tool.
If you park the car and place the transmission in drive, and then shut the ignition, the car can roll. Hence, the brakes are not locked! Chock the wheels to prevent rolling and remove the wheel to remove the brake pads. I have a fairly new rx350 so the need to do a brake job has not come up. When the time comes, I will try this method to see if it works. In the meantime, if someone does this method and it works, please let us all know
Old Oct 30, 2018 | 01:33 PM
bionictony's Avatar
bionictony
is it like this?
https://media-cf.assets-cdk.com/team...TG_Outline.pdf
Old Oct 31, 2018 | 07:03 AM
ravenuer's Avatar
ravenuer
Originally Posted by bionictony
Gee, maybe someone will come up with a simple cable actuated parking brake and eliminate all that nonsense!
(thx for posting that btw, it was interesting)
Old Oct 31, 2018 | 04:43 PM
wktjr's Avatar
wktjr
I like this better.
Old Nov 5, 2018 | 08:28 AM
chunktwo's Avatar
chunktwo
its not about the electronic brake being engaged or not - you can have your car in PARK and not have the electronic brake engaged..
it is about retracting the piston so that the new pad (which will be thicker) and the new rotor (which will be thicker) than the old worn components, will all fit back up together.
Old Nov 12, 2018 | 06:28 AM
bobgailw's Avatar
bobgailw
Default what's different about this brake caliper
What is so different about this brake caliper that the brake piston cannot be retracted the usual way? Do you have any diagrams or photos showing the difference you mentioned?
Old Nov 21, 2018 | 07:51 AM
chunktwo's Avatar
chunktwo
you can search google for images or youtube for ppl explaining it. but the difference is what use to be mechanical and you can turn the rear piston back has replaced by electronics and a motor.
here is a video of one example and explains it -
you can probably still turn the piston back but you need to do it with force and you run the chance of damaging the motor.
Old Nov 21, 2018 | 05:48 PM
wktjr's Avatar
wktjr
$200 on Amazon. Ridiculous.
Found this:
https://www.autoserviceprofessional....-parking-brake
chroma23
CT 200h Model (2011-2017)
Sep 2, 2014 10:58 AM
primecut
IS F (2008-2014)
32
Jan 11, 2010 02:56 PM
chuckli
Suspension and Brakes
Mar 28, 2009 02:28 PM
GS400Lex
GX - 1st Gen (2003-2009)
Jan 3, 2007 03:36 PM
