Creaking Sounds
Old Jun 21, 2018 | 05:28 AM
Pedroski's Avatar
Pedroski
Default Creaking Sounds
Has anyone had any issues with creaking noises coming from the rear upper cabin region when experiencing body twist/flex (sloping driveway), or just generally when opening and closing the tailgate? The dealer has advised me it isn't trim related and is currently under investigation. It sounds like an old fishing trawler at the moment, but I've been assured it isn't structural. I have a 2017, RX 350 F Sport. Thanks in advance.
Old Jun 21, 2018 | 06:15 PM
lexnewbi's Avatar
lexnewbi
I had two mayor creaking issues. One was the rear side plastic spoiler trim flexing with the top hatch spoiler trim. I complained to Lexus and they could not reproduced it. I fixed it myself by disassembling the trim pieces and putting a piece of rubber door insulation were the two plastic pieces met.
The second was on the rear floor of the tailgate. Took several complaints to the Lexus dealers until they were able to reproduce it. Then it took them three days to fix it. I don’t remember what it was, but has reoccurred since last year.
Old Jun 22, 2018 | 05:27 AM
chunktwo's Avatar
chunktwo
i have heard some creaking - but nothing that really bothered me at all or seemed out of the ordinary. maybe my threshold is higher because our other cars were nearly 12 years old - so they were filled with all sorts of noises.
the only noise i hear periodically and is starting to worry me... is a slight popping sound and can be felt every so slightly in the steering wheel. only happens when the car is stopped at a light and i either move the steering wheel (left or right) or when i left of the brake to start moving on the green light. doesn't happen consistently at every light... but has happened enough that i remember...
please post back when you find the root cause. thank you.
Old Jun 22, 2018 | 07:45 AM
PeeVee's Avatar
PeeVee
In this thread I explained my case:
https://www.clublexus.com/forums/rx-...ve-driver.html
Old Jun 22, 2018 | 10:05 AM
vuong05's Avatar
vuong05
I had a creaking sound that came from the passenger side near the rear wheel. Turns out, my bushings needed some lubrication as they were dry. Dealer took care of it when I mentioned it to them during my oil change service. No other creaking sound that I can tell at the moment.
Best of luck with solving your issue.
Old Jun 23, 2018 | 08:34 AM
Pedroski's Avatar
Pedroski
Is it me, or does Lexus have a quality control problem with this model? I've had steering, gearbox and air-conditioning issues with this car. Creaks, rattles and vibration. What a dud. I'll keep you posted regarding the creaking noise. Have a sneaky suspicion this has something to do with a failed weld or adhesive considering it isn't trim related.
Old Jun 23, 2018 | 09:09 AM
ravenuer's Avatar
ravenuer
Whenever you employ mass production of mechanical things, you'll never achieve 100% perfection. Even the Space Shuttle had problems. My RX has been "perfect"......so far!
jonas's RX
Feb 19, 2019 07:40 AM
evogt500
RX - 3rd Gen (2010-2015)
Oct 15, 2015 05:08 PM
taojonz
Apr 3, 2013 04:07 PM
suprat95
Sep 24, 2010 12:47 PM
krzys4
Feb 13, 2010 04:11 AM
