Replacing wiper blades?
Old Jun 4, 2019 | 07:36 AM
  #61
rxtimes2's Avatar
rxtimes2
Originally Posted by gregjhonda
I bought the Lexus rubber blade refill only online. They are a cinch to replace and cost me $29.04 for the set of 3 and $4 shipping and they work like a dream. The local Toyota dealer offered to match mine up with the Highlander blades but I did not have my car with me at the time and he couldn't figure out the equivalent Toyota P/N. The ebay seller is a Lexus dealer!
https://www.ebay.com/itm/LEXUS-OEM-F...53.m2749.l2649
Did you have any problem with the (metal?) cap lock? Did the eBay inserts come with new cap locks? Did the rear insert install the same way as the fronts? I am just full of questions. Wish there was a youtube video for the 4th gen RX, but couldn't find one.
Old Jun 7, 2019 | 08:36 AM
  #62
gregjhonda's Avatar
gregjhonda
I just used a small tool to release the cap lock after studying it for a few seconds. There's no need for new cap locks. What I received looked like genuine Lexus parts and came in Lexus factory packaging. You can get the front wipers to park in an accessible location using the procedure outlined in the owner's manual. The rear wiper I just killed the ignition when it was out of the home position and it stayed put.
Old Jun 7, 2019 | 12:11 PM
  #63
rxtimes2's Avatar
rxtimes2
Thanks for the update. Do you think this will work.
Old Jun 7, 2019 | 05:10 PM
  #64
mikemu30's Avatar
mikemu30
Originally Posted by Cocal
There are no refills as they are beam blades and you have to buy the whole blade, but there are other manufacturers, in wipers you get what you pay for so don't go cheap if you want them to do a good job.
Wrong - you can replace only the insert if you choose. Me - I replace the entire blade.
Old Jun 7, 2019 | 08:08 PM
  #65
Cocal's Avatar
Cocal
Before you say Wrong, how do you replace an insert that doesn't exist in a 2017 RX. They only have beam blades where there are no inserts.
Old Jun 8, 2019 | 02:31 AM
  #66
rxtimes2's Avatar
rxtimes2
I have seen both the inserts and the whole blades on eBay for a decent price (from a Lexus dealer). Is that where you get yours?
Old Jun 8, 2019 | 03:08 AM
  #67
Freds430's Avatar
Freds430
Inserts are $10 and $9 dollars. Use cl5 for a 10% discount.
https://www.mylparts.com/v-2017-lexu...her-components
Old Jun 9, 2019 | 12:46 PM
  #68
mikemu30's Avatar
mikemu30
My 17 is a beam that includes an insert. Again I would never bother with the inserts as the entire beam/blade is a simple change.
Old Jun 9, 2019 | 02:12 PM
  #69
Cocal's Avatar
Cocal
Mine doesn't, it's like my MB the blade is a one-piece affair.
Old Jun 9, 2019 | 02:19 PM
  #70
mikemu30's Avatar
mikemu30
I guess yours came with after market parts. Look at page 603 of the manual.
Old Jun 9, 2019 | 02:33 PM
  #71
Cocal's Avatar
Cocal
Thanks for bringing this to my attention! I only went by looking at the blade and I could not see anything resembling an insert, so I imagined the to be like the Benz.
I can't see myself going through all that though, I'll get the whole blade and be done.
Old Jun 9, 2019 | 02:42 PM
  #72
mikemu30's Avatar
mikemu30
I agree - I replaced them before the winter and didn't even consider the inserts. Went with Trico OEM fit which work well.
Old Jun 9, 2019 | 07:01 PM
  #73
Freds430's Avatar
Freds430
I take the blade off the car and bring it inside and replace the inserts and both take less then 5 minutes. The insert is $9 and the blade is $20.
Old Jul 18, 2019 | 10:57 AM
  #74
mrmonster's Avatar
mrmonster
Question Aftermarket wiper blades
I picked up a set of rain-x wiper blades but it doesn't seem to be possible to install these. The attachment mechanism on the RX is totally different than what the stand alone aftermarket wipers use. Are we stuck with using OEM refills?
Old Jul 18, 2019 | 11:15 AM
  #75
mikemu30's Avatar
mikemu30
Shop for replacements that indicate OEM fit. I replaced with Tricos and they fit fine. Not refills but the entire blade.
